Fram temperature logger
Results 1 to 5 of 5
    Default Fram temperature logger
    i knocked up this simple example to test a few ideas on fram algorithms while waiting for my pcbs to to arrive. it reads the temp every 30 seconds and once every 6 minutes logs it to a circular buffer in fram with 256 elements of depth. that just over 24 hours worth, the head and tail are also stored in fram so it can resume where it left off when interrupted.
    the as6221 temp sensor is the bees knees of temperature sensors , super accurate and no detectable self heating at all
    '*  Name    : FRAM.BAS                                          *
    '*  Author  : richard                                           *
    '*  Notice  : Copyright (c) 2022 caveat emptor                  *
    '*  Date    : 23/09/2022                                        *
    '*  Notes   :  as6221 + MB85RC256V 24HR TEMPERATURE DATA LOGGER *
    '*          :  256 BYTE CIRCULAR BUFFER IN FRAM  PIC12F1822     *
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    DEFINE INTHAND   disp
    DEFINE I2C_SLOW 1    ; for high speed osc
    DEFINE I2C_HOLD 1    ; chip employs clock stretching
        as6221_ADDRESS CON 144
        fram__ADDRESS  CON 160
        OSCCON  = $70
        DEFINE OSC 32
        LATA.0 = 1            ;debug
        trisa = %11111111     ;debug
        ANSELA = 0
        RCSTA = $90   ' Enable serial port & continuous receive
        TXSTA = $24   ' Enable transmit, BRGH = 1
        SPBRG = 64    ' 9600 Baud @ 32MHz, 0.04%
        SPBRGH = 3
        BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
        'SEND C  TO CLEAR P TP PRINTOUT
        clear
        PAUSE 2000
        hserout [ "READY" ]
        SDA VAR PORTA.5
        SCK VAR PORTA.4
        timer1_reload con  45537  '10mS
        millies   var word      BANK0
        rxbuff    VAR BYTE[6]   BANK0  ;5 CHR + NULL
        rxinx     VAR BYTE      BANK0
        rxflg     VAR BYTE      BANK0
        NOW       VAR WORD
        dTIME     VAR WORD
        readtime  VAR WORD
        REG       VAR BYTE
        Temp      var word
        dc        var word
        head_fs   VAR BYTE    ;fram shadow var
        tail_fs   VAR BYTE    ;fram shadow var
        rd_ptr    VAR BYTE
        inx       var word
        ;fram addr pointers
        fram_ptr_t con $100    ;to temperature data store
        fram_ptr_v con 0       ;to variable data  store
        head       con 0       ;head_fs
        tail       con 4       ;tail_fs
        inx = RCREG   ;DUMMY READ CLR RCIF
        T1CON   = $21
        PIR1    = 0
        intcon  = $C0
        pie1.0  = 1
        PIE1.5  = 1
        ;init  fram
        inx = fram_ptr_v
        I2CREAD  SDA,SCK,fram__ADDRESS,inx + head,[head_fs]
        I2CREAD  SDA,SCK,fram__ADDRESS,inx + tail,[tail_fs]
        hserout [ 13,10,"init H/T ",dec head_fs,"/",dec tail_fs]
        GOSUB GET_NOW
        if ((NOW-readTIME)>3000) then    '30 sec   ie 3000*10Ms
            GOSUB GET_tmp
            readTIME = now
        if ((NOW-dTIME )>36000) then     '6 min LOG READING
            GOSUB FWR_tmp
            dTIME = now
        if rxflg then    'SEND C TO CLEAR P TO PRINTOUT WITH A CR [/R] TERMINATION
            hserout [13,10, str rxbuff,13,10 ]
            IF  rxbuff[0]== "C" THEN
                head_fs=tail_fs
                I2cwrite  SDA,SCK,fram__ADDRESS,inx + head,[head_fs]
            ELSEIF rxbuff[0]== "P" THEN
                GOSUB fram_read_t
            rxflg=0
            rxinx=0
    GET_NOW:   ;millies x 10
        pie1.0 = 0
        NOW = MILLIES   ;millies x 10mS
        pie1.0 = 1
    GET_tmp:    ;READ AND PRINT TEMPERATURE H/T
        REG =  0
        I2CREAD  SDA,SCK,as6221_ADDRESS,REG,[temp.highbyte,temp.lowbyte];
        dc = temp*100
        dc = div32 128
        hserout [ 13,10,"temp c#",9,dec dc/100,".",dec2 dc//100,9,dec head_fs,9,dec tail_fs ]
    FWR_tmp:      ;WRITE "temp" TO BUFFER @HEAD
        I2cwrite  SDA,SCK, fram__ADDRESS,fram_ptr_t + head_fs*2 ,[dc]
        head_fs = head_fs+1
        inx = fram_ptr_v
        if head_fs=tail_fs then
            tail_fs = tail_fs + 1 ;CIRCLE ovrflw
            I2cwrite  SDA,SCK,fram__ADDRESS,inx + tail,[tail_fs]
    fram_read_t:  'PRINTOUT  BUFFER
        inx = fram_ptr_v
        I2CREAD  SDA,SCK,fram__ADDRESS,inx + tail,[rd_ptr]
        hserout [ 13,10,"DATA :-",13,10]
        while (head_fs-rd_ptr)
           I2CREAD  SDA,SCK, fram__ADDRESS, fram_ptr_t + rd_ptr*2,[dc]
           hserout [ 13,10,dec3 rd_ptr," temp",9,dec dc/100,".",dec2 dc//100 ]
           rd_ptr = rd_ptr + 1
        wend
    asm
    disp
        BANKSEL 0
        BTFSS PIR1,5     ;RXISR
        goto t01         ;NEXT ISR
        BTFSC _rxflg ,0  ;BUFF full
        GOTO SFT
        movlw high(_rxbuff+1)
        movwf FSR0H
        movlw LOW(_rxbuff)
        movwf FSR0L
        MOVF _rxinx,W
        ADDWF  FSR0L ,F
        INCF   _rxinx,F
        movlw 6          ;BUFF SIZE
        SUBWF  _rxinx,W  ;full UP ?
        BTFSS STATUS ,Z
        GOTO NB
        CLRF   _rxinx    ;ROLL OVER
    SF
        INCF FSR0L,F
        CLRF INDF0      ;NULL TERMINATE
        BANKSEL 0
        BSF  _rxflg,0    ;full UP / SET FLAG
    SFT
        BANKSEL RCREG
        MOVF RCREG,W     ;JUST CLR FLG
        GOTO t01         ;NEXT ISR TO SERVICE
    NB
        BANKSEL RCREG
        MOVF RCREG,W
        MOVWF  INDF0     ;SAVE CHR
        movlw 13         ;TERMINATE ON '/r'
        SUBWF   INDF0,W
        BTFSC STATUS ,Z
        GOTO SF          ;SET FLAG
        ;GOTO disp       ;RECHECK FIFO
    t01     ;tmr1 isr
        BANKSEL 0
        BTFSS PIR1 ,0
        goto ex
        BCF  T1CON,0     ;stop timer
        MOVLW HIGH (_timer1_reload)
        ADDWF TMR1H,F
        MOVLW LOW (_timer1_reload) ;Add TimerReload to the_
        ADDWF TMR1L,F              ; value in Timer1
        BTFSC STATUS,C
        INCF  TMR1H,F
        BSF  T1CON,0      ;START timer
        BCF PIR1   ,0
        MOVLW 1
        ADDWF _millies,F
        BTFSC STATUS,C
        INCF  _millies+1,F
    ex
        RETFIE
    endasm
    printout
    READY
    init H/T 156/132
    temp c# 22.63 156 132
    temp c# 22.60 156 132
    P
    DATA :-
    132 temp 22.91
    133 temp 22.91
    134 temp 22.90
    135 temp 22.96
    136 temp 22.98
    137 temp 23.10
    138 temp 23.05
    139 temp 22.67
    140 temp 22.54
    141 temp 22.46
    142 temp 22.38
    143 temp 22.26
    144 temp 22.26
    145 temp 22.73
    146 temp 22.77
    147 temp 22.83
    148 temp 22.73
    149 temp 22.71
    150 temp 22.81
    151 temp 22.76
    152 temp 22.74
    153 temp 22.57
    154 temp 22.66
    155 temp 22.67
    Default Re: Fram temperature logger
    Nice chip this AS6221. But how on earth can one solder this tiny little chip?
    I think this line:
    can be
    hserout [ 13,10,"temp c#",9,dec dc/100,".",dec2 dc,9,dec head_fs,9,dec tail_fs ]
    The dc variable holds the temp in x1000, right? So printing the last 2 digit with DEC2 does not need //100.
    i can't i can barely see it. used a dev board , their not cheap either.
    when i first saw the board i thought they had sent me a blank board the smd resistors and caps are grains of sand
    or dust specs
    no its temp x100 and the second term is the remainder {modulus) I'm not confidant that a simple division would ever be correct
    I am not sure I follow.
    dc var as I understand, holds the value say, 2236. This represents the value 22.36 degrees celcious.
    To display it as integer, dc/100 is used and for the floating part, DEC2 dc will display the least significant digits, that is 36. So the use of //100 I think, only increases the code size.
    and it does , that's another one of those things i have micro managed forever for no good reason
    duly noted thanks
  1. Replies: 27
    Last Post: - 4th November 2011, 18:44
  2. Fram Memory
    By MARGARITA in forum Serial
    Last Post: - 1st October 2008, 13:30
  3. Smartcard logger
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 5th October 2006, 11:46
  4. GPS logger?
    By Gonzzo in forum Off Topic
    Last Post: - 13th February 2006, 13:25
  5. accessing fram memory
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 8th March 2005, 12:29
