pbp math help please!!!
Results 1 to 4 of 4
    houa's Avatar
    houa Guest
    Angry pbp math help please!!!
    for some reason i keep on getting inaccurate readings from the following equations...
    M VAR BYTE
    A VAR word
    B VAR word
    C VAR word
    D VAR word
    W var byte
    HH var word
    weight var byte
    BMIA VAR BYTE
    BMIB VAR BYTE
    BF VAR BYTE
    CALBF:
    B=82/1000
    A=415/100
    C=9842/100
    D=7676/100
    IF (M=1) THEN
    GOsub MALEBF
    Else
    GOsub FEMALEBF
    goto RT
    MALEBF:
    BFA = (A*WAIST) 'waist(inches)
    BFB = (B*W) 'W=weight(lbs)
    BF = (-C + BFA - BFB)
    BF = BF/W
    BF = BF*100
    FEMALEBF:
    BFA = (A*WAIST)
    BFB = (B*w)
    BF = (-D + BFA - BFB)
    BF = BF/w
    BF = BF*100
    RT:
    BODYFAT = BF
    CALBMI:
    HH=HEIGHT*HEIGHT 'example use 70 inches
    BMIA=WEIGHT
    BMIB=HH
    BMI=WEIGHT/HH
    BMI=BMI*703
    Wink Rtfm !!!!
    Just read the manual : PBP works with INTEGERS !!!
    Talking PBP can't handle floating point math
    PBP can't handle floating point math.
    However, there are work-arounds.
    Go to this link:
    http://www.melabs.com/resources/fp.htm
    Also, do a search of this forum.
    You should get tons of information.
    Floating point is a very "popular" topic.
    I'm sure somebody here will be able to help you.
    Cheers!
    ---> picnaut
    Mar 2005
    Iowa, USA
    Post Math Link
    HERE'S an excellent write up on using integer math. Hope it helps.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. Math Operations on pbp
    By Jannia04 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2007, 15:33
  3. Another math problem for PBP
    Last Post: - 2nd April 2005, 20:59
  4. Nasty PBP math help ?
    By Martin in forum mel PIC BASIC Pro
    Last Post: - 30th March 2005, 09:46
  5. PBP 16-bit ADC result math
    By sonic in forum mel PIC BASIC Pro
    Last Post: - 13th March 2005, 14:21
