DS1994 Memory/Time iButton - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
  1. #41
    Feb 2004
    Germany
    You can find the "final" version in the code examples section:
    http://www.picbasic.co.uk/forum/show...=3041#post3041
    regards:
    Ralph
  2. #42
    brighton
    Quote Originally Posted by Melanie
    Here's the solution to item 2 from my previous post yesterday (as it's the easiest to complete). It's the inverse of the CalculateDateFromLinear subroutine.
    This subroutine takes YEAR, MONTH and DAY and returns with Linear DAYS starting with DAYS=0 for 01/01/2000. Note, it's only good for 100 years as it does NOT account for year 2100 leap anomaly. I'm reusing variables and EEPROM presets previously defined in your program.
    	'	Subroutine Calculates Linear Days from Date
    CalculateLinearFromDate:
    	DAYS=0
    	For CounterA=0 to YEAR
    		TempA=CounterA//4
    		If CounterA < YEAR then
    			TempB=365
    			If TempA=0 then TempB=TempB+1
    			DAYS=DAYS+TempB
    		Next CounterA
    	IF MONTH > 1 then
    		For CounterA=1 to MONTH-1
    			Read (CounterA+20),ByteA
    			If TempA=0 then
    				If CounterA=2 then ByteA=ByteA+1
    			DAYS=DAYS+ByteA
    			Next CounterA
    	DAYS=DAYS+DAY-1
    Oh and in this routine, my MONTHS start counting from 1, so CounterA+20 is valid here!
    I can't seem tp follow the variable delaration of the program
    Can i use this with my DS1307 RTC
    i can read YEAR, MONTH and DAY from my RTC what variable to i send them to before calling the sub.
    i am confused here
    Isaac
  3. #43
    brighton
    Smile
    Hi Nav / Mel
    I have being reading the trend DS1994 Memory/Time iButton and it is very very interesting and just need your help in using the program.
    I am using a DS1307 RTC of which i read the following variables
    Date =23
    Month=03
    Year=05
    Hour =21
    Mins =30
    Seconds=30
    to give me 23-03-05 21:30:30 (my data & time)
    which are all byte variables
    But i want to convert this to Linear DAYS and add 365 but can't figure out which subroutine to use as from my understand the subroutines are looking for a 32bit number
    Could you be kind enough to explain to me
    Best Regards
    Isaac
  4. #44
    Feb 2004
    Germany
    ISAAC,
    the Subroutine "CalculateLinearFromDate" isn't really that complex, is it?
    with your variables beeing:
    Date =23
    Month=03
    Year=05
    Hour =21
    Mins =30
    Seconds=30
    all you need to do is:
    rename your VAR "Date" to "DAY"
    (or create an alias)
    and declare the following variables in addition:
    CounterA VAR Byte
    TempA VAR WORD
    TempB VAR WORD
    DAYS WAR WORD
    once you have read the DS1307 just
    GOSUB CalculateLinearFromDate
    and you will find the result in "DAYS"
    regards
    Ralph
  5. #45
    Australia
    Question
    Hi Ralph & Melanie,
    How to calculate the elapsed hours between 16:30:45 (HH:MM:SS), 28/05/2005 (DD/MM/YYYY) and 02:26:38, 01/08/2004.
    Assume the elapsed time is limited to less than one year. Can I use the CalculateLinearFromDate subroutine to do the job?
    Best regards,
    Yuantu Huang
  6. #46
    CalculateLinearFromDate will account for the DAYS. Multiply by 24 for your TotalHours. Then to account for the Hours...
    If EndDateHours > StartDateHours then TotalHours=TotalHours+(EndDateHours-StartDateHours)
    If EndDateHours < StartDateHours then TotalHours=TotalHours-(StartDateHours-EndDateHours)
  7. #47
    Australia
    Hi Melanie,
    Thank you very much.
    Yuantu Huang
  8. #48
    Sep 2006
    Default ibutton 1990a
    When you're done, you can create Ralph1994 and send it with a resume of what it does to MeLabs for inclusion in their Submitted Programs section... people must be getting bored with my offerings.
    hi,
    i succeed to read ibutton (1990a) and display it on lcd..but iam not able to store serial# on variable..i want to compare ibutton's serial nos.iam trying to read multiple ibuttons and store their sr# in eprom.. if sr# is 1 of the stored # then do something...
    Thanking you
    Regards.
  1. Writing & Reading to iButton EEPROM
    By crhomberg in forum Code Examples
    Last Post: - 6th October 2008, 20:40
  2. DS1920 IButton
    By scottl in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2007, 01:39
  3. iButton
    By menze in forum mel PIC BASIC Pro
    Last Post: - 27th June 2006, 00:48
  4. RS485 - ibutton network
    By ccsparky in forum mel PIC BASIC Pro
    Last Post: - 6th June 2005, 22:48
  5. Dallas DS1994 iButton CLOCK
    By NavMicroSystems in forum Code Examples
    Last Post: - 29th September 2004, 23:19
