setting up HPWM
Results 1 to 9 of 9
Thread: setting up HPWM
    Oct 2006
    Question setting up HPWM
    Hi ,
    I want know because using the Picbasic Pro function HPWM the max frequency at any oscillator speed is 32.767 kHz, but and using manual register setup, using 20 MHz Xtal can get 2 MHz.
    manual register setup for 1 mhz PWM PIC 16F873
    PR2 = 4
    T2CON = %0000100
    CCPR1L = 2
    CCP1CON = %00011100
    Freq out 1.0 MHz 50 % Duty Cycle
    interesting link :http://www.micro-examples.com/public...alculator.html
    regards
    sunny
    You can't have 2MHZ, it's going to be 1.66666MHZ or 2.5MHZ for that crystal speed
    For 1.66666MHZ and a huge 5 bit resolution
    PR2 = 4
    T2CON = %00000100
    CCPR1L =1
    CCP1CON = %00101100
    For 2.5MHZ and 5 bit resolution
    PR2 = 1
    T2CON = %00000100
    CCPR1L =1
    CCP1CON = %00001100
    don't forget to set the TRISx bit.
    If you really need 2MHZ, 40MHZ or 48MHZ crystal will work.
    Oct 2006
    Hi Steve,
    May be I don't explain me very well ( sorry about my English ! )
    Im concerned why using PBP HPWM function the max freq be 32767 Hz.
    DEFINE CCP1_REG PORTC 'Hpwm 1 pin port
    DEFINE CCP1_BIT 2 'Hpwm 1 pin bit
    DEFINE HPWM2_TIMER 1 'Hpwm 2 timer select
    HPWM 1,127,32767 ' Send a 50% duty cycle PWM signal at 32767 Hz
    ( PBP MANUAL : The highest frequency at any oscillator speed is 32767Hz )
    Settings manually the registers and don't use PBP HPWM function i can get too much frequency range to the ouput of PWM .
    Best Regards
    Sunny
    Ok i try again, is the question is Why the HPWM can't provide more than 32.767 KHZ?
    Don't worry about your english... i know what you mean and how hard it is.. i'm french.. but Canadian (cool down Alain )
    Oct 2006
    Thumbs up
    Hi Steve ,
    ( Ok i try again, is the question is Why the HPWM can't provide more than 32.767 KHZ? )
    Yes I want know why !
    Sunny
    P.S :
    I'm be concerned about some statements used in a code example that you early write in another post.
    (Fullfilling lookup tables )
    @CSize=CODE_SIZE ; get the PIC Codespace size
    LookupStart=(CSize*1024)-512
    ' get the Lookup first address
    ' As i used the bootloader i just move
    ' the adress to a x place
    for the frequency limitation i guess it's an assembler maths limitation. it's hard to fit millions or 1/milions in a 16bit maths routine and/or in a Word size variable
    Look in your datahseet to know how to calculate the PR2 value and search for HPWM in PBPPIC14.LIB file to know how the calc are done.
    What do you want to know?
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
  3. Setting up 5 HPWM pins on 18F4680
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2006, 05:54
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
