PIC 2 PIC communication
Results 1 to 17 of 17
    Mario's Avatar
    Mario Guest
    Quote Originally Posted by mister_e
    If it was as this simple... Manchester and any other method would never exist
    It will depend of tons of elements.. this is why i hate RF stuff.
    Try to keep your lady Happy without any 'Preamble' and good method... May work sometimes...
    If there are many (tons) thing i have to take in consideration to transmite one byte using my TX /Rx ......
    can you specify what these factor to make this thing work.
    1- Do I need another chip or assistance in addition to PIC16f84A (or just I connect the module directly to pic).
    2- Is it a programing (code) problem.
    3-Even when I send 170 decimal which is 0101 0101 in binary (easy for reciver to detect) I'm not receiving any thing.
    by the way I try also to use HT12E /HT12D encoder decoder but it didn't work.
    Cool
    Hi Mario, check your digital output on your receiver with a scope, if there is an output and if the polarity is the same as the input of the transmitter, if I had your E-mail addy then I can send you some schematics with sample code or if you can get to my site, I have some samples there, ask Melanie how to get there (sorry for the poor English)
    Mario's Avatar
    Mario Guest
    Quote Originally Posted by ChrisMicro
    my e-mail address ( [email protected] ) thanks alot
    smeet's Avatar
    smeet Guest
    Default same problem.. pls help
    Hi I am trying to send packets of data using HSErout instead of SErout......The reason being when I try to use serout .. my A/d conversion is not as responsive as in Hserout.
    This is the code I am trying to use.. Pls tell me if this is the right approach or not...
    hserout ["SYNC",B2] using UART and I have also tried software using
    serout2 PORTB.6,T1200,["SYNC",B2]
    here B2 stores the A/d results...
    for serin :
    the hardware code is
    HSERIN 1,Main,[wait ("SYNC"),B0]
    and software is SERIN2 PORTB.4,T1200,10,Main,[wait ("SYNC"),B0]
    Pls reply as I need to get it done today thanks
    Smile Pic 2 Pic
    Hi smeet
    What chip are you using? I believe you are doing an a/d conversion and try to send the conversion.
    How many bites are you trying to send at a time? you can put your bites in an array var. and then send it, if you let me have your Email then I can send you a sample or two and do you realy need to use the UART?
    Here is a 20 bite array sample:
    First define the array as folow:
    L1 VAR BYTE[20]
    SerOut PORTA.6,N1200,["A",L1[0],L1[1],L1[2],L1[3],L1[4],L1[5],L1[6],L1[7],L1[8],L1[9],L1[10],L1[11],L1[12],L1[13],L1[14],L1[15],L1[16],L1[17],L1[18],L1[19]]
    SerIn PORTA.5,N1200,3000,label,["A"],L1[0],L1[1],L1[2],L1[3],L1[4],L1[5],L1[6],L1[7],L1[8],L1[9],L1[10],L1[11],L1[12],L1[13],L1[14],L1[15],L1[16],L1[17],L1[18],L1[19]
    smeet's Avatar
    smeet Guest
    Default Re:
    Hi ,
    i am using PIC 16F877A... Ill attach my code hre... Im basically trying to send my A/d bits using a 418 Mhz transmitter... If I do not use HEROUt it really slows down my code as I am not using interrupts... I have not used interrupts bfore and need to get this code working in a day.. I d really appreciate your help... Im attaching my transmission and reception code here... Im trying Manchester encoding here and then transmit those 16 bits... I understand that I can send only 8 bits at a time so do u suggest I serout 2 array byte and serin two at the other end... I noticed you have added N1200 instead of T1200... CAn i use T1200..
    My email is [email protected]
    Part of the Code for serout :
    A: Pause 5
    If ADCON0.2 = 1 Then A
    B0 = ADRESH>>4
    B0=B0<<4
    ADRESH = 0
    ' PORTD=B0
    ADCON0 = %00111001
    Pause 5
    ADCON0.2 = 1
    B: pause 5
    if ADCON0.2 = 1 Then B
    B1 = ADRESH >> 4
    ByteIn = B0+B1
    PORTD = ByteIn
    GOSUB Encode
    'hserout [B2]
    hserout ["A",Manch] // I guess I went wrong here... Can I split Manch as 2 bytes c0 and c1 and use Hserout
    'serout2 PORTB.6,N1200,["A",B2]
    PAUSE 5
    GOTO Main
    Encode:
    for Index = 0 to 7
    if ByteIn.0[Index] = 0 then
    Manch.0[Index*2] = 0
    Manch.0[Index*2+1] = 1
    Manch.0[Index*2] = 1
    Manch.0[Index*2+1] = 0
    next Index
    For Index = 0 to 7
    Manch.0[(Index*2)] = ~ByteIn.0[Index]
    Manch.0[(Index*2)+1] = ByteIn.0[Index]
    'Next Index
    'Return
    smeet's Avatar
    smeet Guest
    Default Re:
    I have shown Next Index and Return as commented.. They are not commented though...
  1. communication of pic 18f4520 and cell phone
    By Alisha in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 12:47
  2. Replies: 11
    Last Post: - 12th July 2008, 03:36
  3. pic to pic communication pic2pic
    By aftab in forum mel PIC BASIC Pro
    Last Post: - 8th October 2007, 18:16
  4. USB communication with pic
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 15th August 2006, 00:43
