Arraywrite SKIP not supported, DEC for common variable not supported, any ideas?
Results 1 to 10 of 10
    Default Re: Arraywrite SKIP not supported, DEC for common variable not supported, any ideas?
    The addition of $30 will not convert numeric 123 in a three byte ascii value as requested. Either way two words are not enough in the first place. For a byte you need three bytes after the conversion, so for two bytes you need total 6 bytes holding the ascii values.
    I suppose t5 and t6 are bytes. The following will read three bytes for t5 and another three bytes for t6 into temp array. If value of say t5 is 5 then the array temp will be "0","0","5" in ascii format.
    arrayread temp,[dec3 t5,dec3 t6]
    then you can transfer the 6 bytes to the place you want in the final array.
    for a 16 byte buffer going to this much trouble to format the last 8 bytes seems unproductive
    why not just format the whole thing properly in one go to start with ?
    Why update whole screen all the time, when I need only two digits to be changed?
    Why update the buffer at all when you can do partial screen updates ?
    if the buffer is not part of the screen update process then what purpose does it serve ?
    makes little to no sense to me
    The screen update routine is called once per second, according to time change, which is provided by DS3231.
    However, other subroutines are not synced to clock seconds and have own "schedule" of being called.
    So it's quite logical to have data ready, but update screen once per second.
  1. Array syntax not supported
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 29th December 2015, 13:48
  2. READCODE pics supported
    By synsyn in forum mel PIC BASIC Pro
    Last Post: - 10th June 2013, 21:52
  3. Is 10F220 supported ?
    Last Post: - 26th November 2009, 21:08
  4. 16F677 supported?
    By 12aBridge in forum mel PIC BASIC Pro
    Last Post: - 9th October 2009, 03:27
  5. PIC16F687 - supported?
    By badcock in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 10:33
