Arraywrite SKIP not supported, DEC for common variable not supported, any ideas?
Results 1 to 10 of 10
    Default Arraywrite SKIP not supported, DEC for common variable not supported, any ideas?
    Hello. I need to have this code:
    ARRAYWRITE TEXTLINE,[DEC T5, DEC T6]
    but to make it write into last bytes of TEXTLINE array, which is 16 bytes long.
    SKIP operator is not supported for ARRAYWRITE.
    I know that I can directly write to array like
    TEXTLINE[X]=Y
    But I need to use DEC modifier, which is not supported for non-array variables.
    Any ideas?
    Default Re: Arraywrite SKIP not supported, DEC for common variable not supported, any ideas?
    Using a temporary var maybe?
    temp=dec t5
    TEXTLINE[X]=temp
    temp=dec t6
    TEXTLINE[X+1]=temp
    No it does not works
    A=DEC B gives "bad expression" error.
    Yeah I forgot that. You have to make the calculations and then assign the value.
    Maybe others have a better idea.
    OK
    If you are wanting to convert to ASCii, just add $30 to numeric values. This works only for single digits 0 >> 9 though.
    The addition of $30 will not convert numeric 123 in a three byte ascii value as requested. Either way two words are not enough in the first place. For a byte you need three bytes after the conversion, so for two bytes you need total 6 bytes holding the ascii values.
    I suppose t5 and t6 are bytes. The following will read three bytes for t5 and another three bytes for t6 into temp array. If value of say t5 is 5 then the array temp will be "0","0","5" in ascii format.
    arrayread temp,[dec3 t5,dec3 t6]
    then you can transfer the 6 bytes to the place you want in the final array.
  1. Array syntax not supported
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 29th December 2015, 13:48
  2. READCODE pics supported
    By synsyn in forum mel PIC BASIC Pro
    Last Post: - 10th June 2013, 21:52
  3. Is 10F220 supported ?
    Last Post: - 26th November 2009, 21:08
  4. 16F677 supported?
    By 12aBridge in forum mel PIC BASIC Pro
    Last Post: - 9th October 2009, 03:27
  5. PIC16F687 - supported?
    By badcock in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 10:33
