centering servomotor using 16F84A
Results 1 to 5 of 5
    Sep 2005
    Malaysia
    Default centering servomotor using 16F84A
    i was wondering if some one could help me check if this piece of code works. I got this picbasic pro code from a book to center servo motors and prototyped the schematic onto a breadboard. when i applied power nothing happened but i did notice that if i were to pull off the wire connected to the +ve of the servo motor and plug back it moves a little. If possible can some one take a pic of the completed circuit of what it looks like on the breadboard so i can check it against mine? Can't take a picture of mine as my digicam is in the shop for repairs. Please help!
    Servo Motor - HiTec HS-322HD
    start:
    PulsOut portb.0, 150	'Send pulse out on rb0
    Pause 18	'Delay needed to send pulse at 55hz
    GoTo start	'repeat
    <font color=red>Here is the schematics</font>
    <img src="http://i3.photobucket.com/albums/y77/drewandangel/fig02.gif">
    -·=»‡«=·- saturnX -·=»‡«=·-
    Question
    Hi, SaturniX
    try this first ...
    start:
    Low PortB.0
    GoTo start 'repeat
    - Be sure your 5v supply can handle more than 500 mA for the servo ...
    - connect servo to Portb.0 via a 220 ohms resistor to protect the PIC.
    - Check all connexions and be sure servo ground and Pic ground connected.
    then apply Power ...
    Sep 2005
    Malaysia
    hi Acetronics,
    thanks for the reply, i will try your suggestion later on as i was playing around with the schematics last night and managed to get it to work. I incorporated a voltage regulator to regulate the power supply to the pic and the motor and guess what it worked. But i never thought of your way Acetronics and will try it later. Thanks again...
    Sep 2005
    Malaysia
    alain, hoping you do read this thread still. i was just reading through wat you posted and i was just wondering, is it necessary to have a resistor between the IC and the servo? I am not that good in electronics yet and slowly learning so your help is much appreciated.
    Wink not necessary ... but ...
    Hi, Saturnix
    Resistor is not compulsory ... but protects the pic from little things : bad cord connexion and servo input capacitor's discharge in the pic's pin ...
    consider a servo input is often a 1 to 4.7µF cap in series with the amplifier ... so plugging the servo when power is on gives strange things ( reason of the LOW command before PULSOUT ...)
  1. Code works on 16F84A but not on 16F88?
    By pharaohamps in forum mel PIC BASIC Pro
    Last Post: - 6th November 2009, 18:29
  2. ICSP using a 16F84a to program 24CXX
    By aftab in forum mel PIC BASIC
    Last Post: - 8th April 2007, 11:39
  3. 16F84A and Optrex LCD
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 17th October 2005, 16:08
  4. RS 485 using 16F84A
    Last Post: - 18th May 2005, 14:46
  5. Help with a 16F84A
    By Lilmanmgf in forum Off Topic
    Last Post: - 16th February 2005, 03:24
