Bin As Variable
Results 1 to 2 of 2
Thread: Bin As Variable
    Jul 2004
    ISRAEL
    Default Bin As Variable
    if someone know if it possible to use with variable in bin command
    SEROUT2.........BIN16 VOLT
    I NEED
    SEROUT2.........BINx VOLT
    Eyal
    Hi Eyal,
    Can't do it the easy way, but this should do the trick.
    ; ----[Send X number of binary digits]----------
    SER_BINx  macro  Port, Pin, Mode, Value, X
    	SEROUT2DPIN?T	Port, Pin
    	SEROUT2MODE?C	Mode
    	SEROUT2PACE?C	000h
    	SEROUT2COUNT?B	X
    	SEROUT2NUM?W	Value
    	SEROUT2BIN?
    ; ----[Force PBP to include the macro's]---(doesn't use any code space)-----
    @ ifdef AddSEROUTcode
       SEROUT2  PORTB.0,396,[BIN16 R0, REP " "\R0.lowbyte]
    @ endif
    SOpin     VAR  PORTB.0
    Volt      VAR  WORD
    BINcount  VAR  BYTE
    Volt = 115
    FOR BINcount = 16 to 1 step -1
        @  SER_BINx  _SOpin, 396, _Volt, _BINcount
        SEROUT2 SOpin, 396,[13,10]
    NEXT BINcount
    ; should send
    0000000001110011
    000000001110011
    00000001110011
    0000001110011
    000001110011
    00001110011
    0001110011
    001110011
    01110011
    1110011
    110011
    10011
    0011
    011
    11
    1
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. WORD vs BYTE variable lengths
    By bartman in forum General
    Last Post: - 28th November 2005, 22:16
  5. Let a variable change from bin to dec.
    By Roy in forum mel PIC BASIC Pro
    Last Post: - 25th May 2004, 20:57
