A/D converter
Results 1 to 7 of 7
Thread: A/D converter
    Oct 2003
    holland
    Then swap the wires !!
    Aug 2005
    Los angeles
    Quote Originally Posted by mat janssen
    Well if this is the solution i wouldn't be asking this question. it's not that simple
    USA - Arizona
    Well, you have your answer:
    Q. Is it possible to use a negative voltage on the A/D input for the pic12f675 ?
    A. Yes is it possible (careful what you ask for).
    Is it recommended? -> No it's not. You could damage the chip and besides your measurement will not go under Vss (GND).
    You could sense the signal even without a negative supply, but here are the guidelines (if you want to operate from positive supply only):
    1) You need the supply rail (Vdd) to extend somewhat above your signal range (i.e., if your signal can swing from +3V to -3V your supply needs to be +6V with some margin). Why is this?
    2) To measure this you need to "reference" the measurement. For this you need an OPAMP.
  1. A/D converter problem
    By netstranger.nz in forum mel PIC BASIC Pro
    Last Post: - 13th September 2009, 08:56
  2. Replies: 9
    Last Post: - 31st July 2008, 09:56
  3. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
  4. A/D converter with pic16f84, i need a help
    By micro in forum General
    Last Post: - 13th December 2005, 22:17
  5. help with pic16f870 a/d converter
    By cammo in forum mel PIC BASIC
    Last Post: - 22nd March 2005, 06:16
