'ERROR: Macro AND?BCL not found in macro file.' What does that mean??
Results 1 to 2 of 2
    polmear's Avatar
    polmear Guest
    Question 'ERROR: Macro AND?BCL not found in macro file.' What does that mean??
    Hello I wonder if anyone has seen this error.
    After sorting through a few wayward endif's this is the only remaining error that pbpw displays. I'm attempting to compile for a PIC 16F628A.
    The code attached is designed to drive a small rover bot using 3 infra red detectors along a black line (hey! a line following robot, how original!) I haven't had the chance to test the code (since it won't compile) although sections have been used in different programs on the same robot.
    Tim Polmear
    polmear's Avatar
    polmear Guest
    Don't worry, I figured it out.
    I was trying to do a bitwise boolean operation as an expression in an If...Then.
    Now I've discovered it's the very least of my problems.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. PBPro error "Macro USBINIT? not found in macro file"
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 4th October 2011, 10:06
  3. Replies: 6
    Last Post: - 4th November 2009, 14:36
  4. ERROR: Macro MOD?TCB not found in macro file.
    By JohnP in forum mel PIC BASIC Pro
    Last Post: - 17th February 2009, 20:10
  5. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 04:56
