Is this legal?
Results 1 to 3 of 3
Thread: Is this legal?
    BertMan's Avatar
    BertMan Guest
    Default Is this legal?
    Can I use nested brackets like this:
    ShiftIn FPU_DATAIN, FPU_SCLK, MSBPRE [FloatByte[0], FloatByte[1]_
    FloatByte[2], FloatByte[3]]
    Default Sure it's Legal
    There's nothing that says you can't use array variables in the SHIFTIN/OUT command. As with everything, try it and see.
    What you can do (a little secret you may not know about) is that you can use normal brackets () around your array variables rather than square ones to distinguish them from the square brackets in the SHIFTIN Command... like so...
    ShiftIn FPU_DATAIN, FPU_SCLK, MSBPRE, [FloatByte(0), FloatByte(1), FloatByte(2), FloatByte(3)]
    By the way, your example had a comma missing after MSBPRE and another after FloatByte[1] either of which whould have cause a compilation failure.
    BertMan's Avatar
    BertMan Guest
    Thanks Melaine. I couldnt find an example that used arrays with the shift commands. Btw, sweet tip on the (). That makes it a little easier to read.
    The code was something I typed up real fast, and not the actual code. This explains the bad formatting
  1. DT-INTs What's legal in an INT handler?
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 19:43
  2. Circuit Maker 2000 "Pro ED" - Up For Grabs!
    By T.Jackson in forum Adverts
    Last Post: - 6th November 2007, 12:51
  3. Not so legal copies of PBP
    By skimask in forum Off Topic
    Last Post: - 30th December 2006, 03:44
  4. Poor relative in Africa
    By websmith in forum mel PIC BASIC Pro
    Last Post: - 15th December 2006, 07:52
