Dummy needs LCD tutorial,
Results 1 to 33 of 33
    TK5EP's Avatar
    TK5EP Guest
    Default Porting Bargraph include to other Picbasic.
    Hi Darrell,
    I too like your include and already posted a question about it, but did not get any answer.
    I would like to use it with another Picbasic.
    In one line you have : Remainder = R2
    What is this R2 ?
    Do you know if your file has been ported to other versions of Picbasic ?
    Quote Originally Posted by Darrel Taylor
    Absolutely Possible!
    You can have as many bars as you can fit on the screen. They can come and go anytime you please.
    Just remember that when you're finished with 1 particular BAR, call the BARgraph macro 1 more time with a 0 value, to clear the area that it used. It's more efficient than clearing the screen, and re-drawing everthing else. Looks better without the flicker too .
    Glad you like it! Thanks!
    You see, there are reasons why you should be using the MeLabs compiler... Darrel's magic code is one of them...
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
