PWM to V with I feedback
Results 1 to 1 of 1
    Feb 2004
    Michigan, USA
    Default PWM to V with I feedback
    I have an application for a voltage controlled current source to drive a bank of Luxeon high power led's.
    I need to use a PWM signal to provide an off to full brightness condition (0 - 2000mA.) I planned on using a simple filter to the non-inverting I/P (+) of an LM351, using the inverting (-) I/P to provide current feedback, and the O/P to drive the gate of a FET.
    The current feedback will connect between the source and a .33R resistor.
    Will this work? I have to use the LM351 and descrete components, no F to V IC's as this won't give any I feedback.
    I'll draw up a schematic and post it shortly.
    EDIT: Just found Mel's circuit for the voltage doubler. This idea is similar except supply is 5v and O/P should be from 0 - 5V.
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. PWM 'channels ...what's that all about then!
    By HankMcSpank in forum General
    Last Post: - 23rd April 2009, 16:49
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 07:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 00:26
