what is hyper terminal?
Results 1 to 5 of 5
    moud_man's Avatar
    moud_man Guest
    Default what is hyper terminal?
    hi
    i saw in a thread
    "If you have windows you could use hyper terminal to connect to pic "
    so can anyone expain briefly how can i use the hyper terminal to connwct to the pic? i know that hyper terminAL is used to connect 2 computers but with pic idonot know
    thnx for reading
    bye
    Dec 2003
    Wichita KS
    Hyperterminal is a program TTY program that comes with all windows operating systems.
    It is equivalant to the OLD BBS communication programs back in the 70's and early 80's.
    You may have to install it off of your operating system... the newer versions of Windows operating system does NOT install it automatically... You must call up your operating system programs, make a checkmark on the Hyperterminal installation, and then you will be good.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    moud_man's Avatar
    moud_man Guest
    well
    that is good but there are some ques. didnot replyed:
    1-what is the operation of that prog?
    2-how i can use it in pic project? or in other wors what is the relation between it and picbasic or pic?
    bye
    Italy
    Q1:
    See this link:
    http://en.wikipedia.org/wiki/Terminal_emulator
    Q2:
    See PicBasic Pro manual:
    5.30. HSERIN
    5.31. HSEROUT
    5.68. SERIN
    5.69. SERIN2
    5.70. SEROUT
    5.71. SEROUT2
    Dec 2003
    Wichita KS
    Hello Moudman,
    MM>>1-what is the operation of that prog?
    2-how i can use it in pic project? or in other wors what is the relation between it and picbasic or pic?<<
    The program operates exactly as if you are communicating between two Personal Computers... It is a simple Teletype Program that can do ASCII echo of data and data transfer.
    You use it in your pic project by selecting serial port for I/O. Select a baudrate that is SLOW (300 baud is good to start out with).
    You can use Serout but you have to invert the signal for the Hyperterm to make sense of it.
    The Hypterterminal only relationship is being able to communictate back and forth from a PC to a Pic Chip. Pic Basic Pro, or PBP has nothing to do with Hyperterminal... PBP is a different kind of software that compiles 1st and 3rd level computer languages to 1's and 0's (Hex format) so that you can load this Hex file inside your PIC chip, and make the PIC chip do the things you want.
    Dwayne
    Ability to Fly:
  1. Key_in from terminal
    Last Post: - 25th May 2009, 16:15
  2. Replies: 13
    Last Post: - 12th May 2009, 17:26
  3. Hyper Terminal Setting for TTL putput
    By ClayE in forum Serial
    Last Post: - 7th June 2008, 06:50
  4. Tapping data from a Unix VT220 terminal
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2006, 04:47
  5. USB Terminal
    By Normnet in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 11:51
