SEROUT without modedefs.bas possible?
Results 1 to 8 of 8
    Default SEROUT without modedefs.bas possible?
    Hello.
    I'm running low on memory, so inclusion of modedefs.bas is not possible.
    All I need to do is to have simple statement like this
     serout buz,t9600, [$7e,$ff,$06,$03,$00,$00,$03,$ef]
    Can I do it without modedefs.bas ?
    Default Re: SEROUT without modedefs.bas possible?
     serout buz,2, [$7e,$ff,$06,$03,$00,$00,$03,$ef]
    Including (or not including) modedefs.bas makes no difference what so ever to the size of the code.
    serout buz,2, [$7e,$ff,$06,$06,$00,$00,$1e,$ef] increases code size from 6549 to 6639 bytes for my particular code.
    but after I uncomment include modedefs.bas
    I'm starting to get the following errors:
    Bad BANK statement
    Bad variable request address 0
    If I reduce my code in size, then these errors go away.
    That is strange as the modedefs.bas file is just an alias file for the text to numbers aliasing. It should not interfere with the code size.
    As is the case with the common alias you do in your program, e.g.
    myval var adresh
    does not change the code size by any means.
    Yes and also modedefs.bas does not like variable named BRIGHT. It gives error, when I try to include modedefs.bas and use that variable
    There's something else going on. Can you post the code?
    It is about 7K compiled, so lots of code in it...
  1. Is modedefs.bas still required for pbp3 ?
    By longpole001 in forum FAQ - Frequently Asked Questions
    Last Post: - 20th July 2014, 23:24
  2. Modedefs.bas
    By mrpeja in forum mel PIC BASIC
    Last Post: - 24th March 2010, 11:56
  3. Modedefs.bas
    By Richardco in forum mel PIC BASIC Pro
    Last Post: - 25th November 2005, 09:58
  4. modedefs.bas
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 21st March 2005, 17:16
  5. Modedefs.bas
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 22:47
