Enhanced PWM Full-Bridge Mode
Results 1 to 3 of 3
    Dec 2021
    Illinois, USA
    Default Enhanced PWM Full-Bridge Mode
    Hello everyone,
    I searched all the forum topics on motor control I could find and went through the manual but I am still at a loss for how to use the Enhanced PWM Full-Bridge mode in PBP for a 18F46K80. Does PBP support this mode or do I have to do an assembly routine that gets called from PBP?
    Thanks for any help that can be given.
    Paul
    2 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    Default Re: Enhanced PWM Full-Bridge Mode
    its not supported, no need to resort to asm though
    simply set the required sfr registers yourself
    eg
       CCP2CON   =  %10001100                      ;enh pwm complementary output
       CCPTMRS   =  CCPTMRS  & %11110011   ;tmr2 for ccp2
       T2CON       =  %00000101
       PWM2CON  = 10                                     ;dead time
       ccpr2l        = 128
    Dec 2021
    Illinois, USA
    eg
       CCP2CON   =  001100                      ;enh pwm complementary output
       CCPTMRS   =  CCPTMRS  & 110011   ;tmr2 for ccp2
       T2CON       =  000101
       ccpr2l        = 128
    In looking at the code I think the CCP2CON would have to be 01xx1100 for forward or 11xx1100 for reverse. I think that is what I got from the manual.
    Thanks again.
  1. Replies: 4
    Last Post: - 7th June 2011, 06:02
  2. Need guidance with DC motor controller - PWM & H-Bridge
    By rfetech in forum mel PIC BASIC Pro
    Last Post: - 12th November 2010, 04:33
  3. PWM with PIC16F88 controlling h-bridge
    By deimantas in forum mel PIC BASIC Pro
    Last Post: - 20th May 2010, 23:03
  4. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  5. Using HPWM in half bridge mode on 16f690
    By Chris Barron in forum mel PIC BASIC
    Last Post: - 29th December 2006, 12:18
