Question About Error Codes From Programmer
Results 1 to 4 of 4
    Dec 2012
    Georgia, USA
    Default Question About Error Codes From Programmer
    I started using PBP 2.6C in 2011 when Darrel Taylor was still on the forum. He helped me with a communications program
    on the PIC-16F877-20/P. He thought me how to use his DT INTERRUPTS to do communications and timers on the PIC-16F877.
    he suggested I use the in-circuit programmer with the board I had purchased. It is a WinPic 800, I also have a MELabs
    programmer but have it set up on my PBP3 system.
    The program has worked great for me so I have not made changes for quite some time.
    however now I have had trouble getting the 16F877 chips, so I have had to purchase on the secondary
    market to get them in a timely manner. I bought a few and having a difficult time getting the
    programmer write the program to the Chips. I am getting the same error on all the chips and cant seem to find the
    meaning of the error code. attached is a snap shot of the screen.
    Thanks in advance for any direction anyone could point me on where to find the
    meaning of these error codes.
    Default Re: Question About Error Codes From Programmer
    What it's saying is basically that the chip does not contain what you expect it to.
    The programmer (and its software) writes .hex file to the chip, it then verifies it by reading it back. Here it expects to read the value 0x29E1 at memory location 0 but instead it reads 0x3FFF which means the chip isn't programmed properly.
    0x3FFF is 14 bits, all ones which is the same as blank.
    Dec 2012
    Georgia, USA
    Thank You HenrikOlsson
    Is there a way to fix this, or does this mean the chips are bad?
    Larryd
    The chips or the programmer could be bad.
    If you have a 16F877 from another batch then try programming that. If it programs properly then the chips are either bad or marginal for use with that particular programmer.
    Perhaps you have another programmer you can try or borrow one from a friend or send one of the chips to a friend with another programmer to try.
    A while back I bought some OTP PROMs from EBAY. My universal programmer (TL866) supported that particular chip but it didn't work so I thought they were fakes. But I asked on a forum if someone with another programmer would be kind enough to try and program the chip for me. It worked fine.
  1. Melabs U2 Programmer question
    By polymer52 in forum Off Topic
    Last Post: - 23rd July 2010, 14:10
  2. Programmer question
    By Sam in forum General
    Last Post: - 13th June 2008, 17:17
  3. Programmer error with memory sizing on 16F68x
    By hvacrtech in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2007, 13:09
  4. programmer question
    By muddy0409 in forum General
    Last Post: - 14th October 2006, 13:05
  5. Programmer question
    By mwhatley in forum mel PIC BASIC Pro
    Last Post: - 4th October 2005, 02:04
