18F part recomendation
Results 1 to 3 of 3
    Just ensure you have the latest versions of PICBasic and MPLAB.
    16F877's progression is really the 18F452, 18F4520 etc. whilst I don't use those parts, I can confirm their smaller brothers the 18F242, 18F2420, 18F252 etc are stable, and I use those where I run out of steam with the 16F876.
    Feb 2005
    Kolkata-India
    Thumbs up I can bet on the 18F452
    Hi there,
    I have used the 18F452 for many many applications and it has never let me down. I tend to use it in the HSPLL mode with a 10MHz crystal for full 40MHz speed. Sometimes while using interrupts it is worth noting that this chip has a high priority interrupt vector and pbp uses the low priority. So setting the configuration for interrupts is important. Also if you are using an LCD a few lines of code in the beginning of the program can indicate problems of STACK OVERFLOW (Weird Reboots).
    IF STKPTR.7 = 1 THEN ' CHECK FOR STACK POINTER OVERFLOW
    LCDOUT "STACK OVERFLOW" ' SHOW IT
    STKPTR.7 = 0 ' CLEAR STACK POINTER OVERFLOW BIT
    PAUSE 5000 ' LET ME READ THE LCD
    IF STKPTR.6 = 1 THEN ' CHECK FOR STACK POINTER UNDERFLOW
    LCDOUT "STACK UNDERFLOW" ' SHOW IT
    STKPTR.6 = 0 ' CLEAR STACK POINTER UNDERFLOW BIT
    Sougata
  1. 16F to 18F transition pains
    By lurker in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 02:35
  2. Super easy 18F print strings to UART
    Last Post: - 27th August 2007, 00:19
  3. Upgrading 16F to 18F
    By Ron Marcus in forum General
    Last Post: - 29th March 2006, 10:44
    Last Post: - 18th December 2005, 00:30
  5. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 20:42
