MicroCode studio crashes while typing in code.
Results 1 to 20 of 20
    Default Re: MicroCode studio crashes while typing in code.
    Several threads on this over the years, as far as I can remember no definitive cause or cure found. It used to crash a lot on my old W7 machine - to the point where it was barely usable, then I built I new machine (5-ish years ago) with W10 and I don't think I've had a crash since.
    One could say it might have to do with a driver, but I guess Henrik you transferred the same stuff on the new machine, right?
    And how possible can it be you have the same configuration with of your old W7 with CuriousOne new W10 machine?
    Tough one it is.
    Well, I took some more time to investigate this issue - I even set-up high speed camera to record my screen, to capture the moment when this error happens. And here are the results.
    In most cases, this error happens when you just finish typing in the statement, and it should change it's color to blue. Or the crash occurs when you start typing after the statement become blue.
    On my old machine - i3-9100F/16GB/RX550 this was not happening. So, for testing purposes, I installed a new SSD on it, did clean install and tested again - no problems found.
    Configuration of new PC is as follows: i3-12100F/16GB/RX6500XT. So since that error was happening when text changes color, I thought that graphics card might be messing up, so I installed that RX6500XT into my old machine and there are no errors, so graphics card is excluded. The only major difference between my PCs are that the new one has new office and visual studio installed too. So maybe they install some dotnetfx or something like that, which messes up PBP.
    I've got another SSD, and will do clean install on the "new" pc, to ensure that everything is ok.
    First of all we need to be clear that it's not PBP that crashes - it's MicroCodeStudio, which is a separate executable. MicroCode studio is developed by a third party, which does not make it easier getting it fixed.
    On my old machine I had VisualStudio of some sort, on the new one I don't. Obviously there are literaly THOUSANDS of other things that are different but that is ONE clue.
    Video / graphics issue is another angle and one that Darrel brought up in one of the threads from many years ago. Again, no definitive cause or cure found.
    I guess safe mode does not produce crashes, right?
    Aug 2011
    Have you tried setting a compatibility mode?
    Yes, no changes, but my computer started showing same behavior in other apps too, even fresh installed windows. I already changed video card - nothing, changed PSU - nothing. Today I changed RAM and let's see what happens.....
  1. Replies: 15
    Last Post: - 28th March 2014, 03:43
  2. microcode studio
    By cable tech in forum mel PIC BASIC
    Last Post: - 28th September 2011, 17:53
  3. Replies: 3
    Last Post: - 1st July 2008, 22:07
  4. Code Folding - Microcode Studio Wish
    By Rob in forum PBP Wish List
    Last Post: - 6th December 2007, 10:11
  5. MicroCode Studio Plus Code Explorer Question
    By enauman in forum mel PIC BASIC Pro
    Last Post: - 7th September 2007, 11:31
