What is causing my problem?
Results 1 to 10 of 10
    Mentor, Ohio
    Default What is causing my problem?
    Hello all!
    It’s been a long time since I’ve posted here but I’ve still stayed in touch. I just made a project using a 16F87 and set 2
    Outputs to 0 and I am getting voltage out of the pin that’s enough to turn the output transistors on. Can anybody give me a reason why a zero on a pin is not a zero? The original project I made back in 2005 was done with a 16F84a and is suppose to be pin compatible with the F87. The original project still works fine but I need another. Help, please!
    Thank you, BobK
    Bombay, India
    Default Re: What is causing my problem?
    Is it possible you did not set the TRISx register (where x is the port name) ? Perhaps the pin is an analog one by default and you haven't configured it for digital use?
    these are what I can think of just now.
    Mentor, Ohio
    Thank you for the fast reply, Jerson.
    I have 2 inputs on port A and the Tris A is =00000011 and the outputs are on port B and the Tris B is =00000000. I have the comparators disabled with CMCON = 7. Is there something missing here? Thank you!
    BobK.
    Aug 2011
    ... set outputs to 0 and I am getting voltage out of the pin that’s enough to turn the output transistors on.
    What voltage are you measuring? Which PORTB pins are you using?
    Bombay, India
    Related to PORTB, I can see that only the ANSEL register is different.
    I have some doubt if the ANSEL needs to be set to 0 on this chip.
    If that does not help, then perhaps you can try by disconnecting the driven load and check if the outputs are following your code intent.
    Aug 2011
    PORTB has no analog functions on the 16F87.
    Have you disabled the WDT?
    Mentor, Ohio
    No I did not disable the WDT. Is that necessary?
  1. Replies: 5
    Last Post: - 5th January 2018, 14:46
  2. Argument out of range - how to find what is causing it?
    Last Post: - 3rd November 2011, 03:00
  3. Fan causing noise in audio circuit
    Last Post: - 28th August 2011, 12:47
  4. MCLR causing trouble . .
    By shahidali55 in forum General
    Last Post: - 21st December 2007, 13:20
  5. Issue with Array causing PauseUS to have 16uS overhead
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 10th November 2007, 09:41
