18F26K80 Serial setting sanity check and 4xPLL.
Results 1 to 21 of 21
    Default Re: 18F26K80 Serial setting sanity check and 4xPLL.
    I also had a bad/fake 20mhz resonator.
    I then tried some Farnell ones and decent crystals all worked ok, even at 96mhz.
    The board actually worked in the car at 96mhz but that is overspec (12mhz) for the 10mhz MCP2515 CAN controllers SPI so I dialled the PIC back to 80mhz for reliability and (10mhz SPI)
    So a decent increase in speed over 64mhz at zero cost so far.
    Now back to the other thread to do some code speed optimisation before I add additional functionality with my extra free time.
    I'll admit, I've been sceptical about relying on overclocking for something that is actually being used but I suppose if it works at 96MHz(!) then dialing it back to 80MHz does provide some margin.
    Since it's going to end up in a car I'd probably test it at something other than room temperature before banking on the extra instruction cycles. I know you said it did work in the car at 96MHz but at what temperature?
    Looking forward to the optimisation thread!
    To be fair it worked ok at 64mhz without any optimisation I'm just being greedy and trying to free up/gain some cycles in advance of other stuff.
    I have a heat gun and freeze spray so it's pretty easy to stress it.
    It's been working fine in the summer sun for last two days at 80mhz.
    30-35C in the car.
  1. Bytes roll over sanity check
    Last Post: - 18th October 2020, 08:23
  2. Setting RTC by Serial input
    By jamie_s in forum Code Examples
    Last Post: - 26th November 2015, 14:57
  3. timer0 10ms setting check
    Last Post: - 1st July 2015, 11:36
  4. looking for a quick sanity check
    By cncmachineguy in forum Serial
    Last Post: - 13th November 2010, 19:53
  5. Block Check on Serial Comms.
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 15th June 2005, 10:27
