Code:'-------------------------- General 18F26K80 configuration --------------------- #CONFIG CONFIG RETEN = OFF ; Ultra low-power regulator is Enabled (Controlled by SRETEN bit) CONFIG INTOSCSEL = HIGH ; High power mode during Sleep CONFIG SOSCSEL = DIG ; Disabled RC0 & RC1 I/0 CONFIG XINST = OFF ; Disabled CONFIG FOSC = HS2 ; External 20mhz Resonator CONFIG PLLCFG = ON ; Enabled CONFIG FCMEN = OFF ; Disabled CONFIG IESO = OFF ; Disabled CONFIG PWRTEN = OFF ; Disabled CONFIG BOREN = OFF ; Disabled CONFIG BORV = 3 ; 1.8V CONFIG BORPWR = ZPBORMV ; ZPBORMV instead of BORMV is selected CONFIG WDTEN = OFF ; WDT disabled in hardware; SWDTEN bit disabled CONFIG WDTPS = 512 ; WDTPS 1:256 = 1.024 Second Timeout CONFIG CANMX = PORTB ; ECAN TX and RX pins are located on RB2 and RB3, respectively CONFIG MSSPMSK = MSK7 ; 7 Bit address masking mode CONFIG MCLRE = OFF ; MCLR Enabled, RE3 Disabled CONFIG STVREN = ON ; Enabled CONFIG BBSIZ = BB2K ; 2K word Boot Block size CONFIG CP0 = OFF ; Disabled CONFIG CP1 = OFF ; Disabled CONFIG CP2 = OFF ; Disabled CONFIG CP3 = OFF ; Disabled CONFIG CPB = OFF ; Disabled CONFIG CPD = OFF ; Disabled CONFIG WRT0 = OFF ; Disabled CONFIG WRT1 = OFF ; Disabled CONFIG WRT2 = OFF ; Disabled CONFIG WRT3 = OFF ; Disabled CONFIG WRTC = OFF ; Disabled CONFIG WRTB = OFF ; Disabled CONFIG WRTD = OFF ; Disabled CONFIG EBTR0 = OFF ; Disabled CONFIG EBTR1 = OFF ; Disabled CONFIG EBTR2 = OFF ; Disabled CONFIG EBTR3 = OFF ; Disabled CONFIG EBTRB = OFF ; Disabled #ENDCONFIG '******************************************************************************* '************************** PBP Basic Defines ******************************** '******************************************************************************* DEFINE OSC 40 '80mhz (If overclocking at 96mhz set define to 48mhz ot if 80mhz set at 40mhz) DEFINE NO_CLRWDT 1 'No Clear WDT Instructions added '*********************** Direct Pic Register Settings ************************ OSCCON = %00001000 'External Resonator OSCCON2 = %00000000 'Clear HLVDCON = %00000000 'HLVCON Disabled T1CON = %00110000 'Timer 1 Setup. 'TRISA = %11111111 'SET PORTA.0-7 Inputs TRISA = %00111111 'SET PORTA.0-5 Inputs 6,7 Outputs TRISB = %00001000 'SET PORTB.3 Input rest as Outputs TRISC = %10010000 'SET PORTC.4,7 Inputs rest as Outputs ANCON0 = %00000001 'Analog Inputs on A0 ANCON1 = %00000000 'No Analog Inputs ADCON2 = %00011110 'SETUP ADC FOSC/64 LEFT JUSTIFY TAD 6 ADCON1 = %00000000 'SETUP ADC SET REFV to VDD & VSS AN0 ADCON0 = %00000011 'SETUP ADC & ENABLE ADC MODULE & START CONVERSION SLRCON = %00000000 'Ports slew at standard rate! SSPSTAT = %11000000 'Configure SPI Module SSPCON1 = %00101010 'Enable SPI Master Mode Fosc/8 (10mhz) Clock idle low SSPCON2 = %00000000 'Configure SPI Module 'bit 3-0 SSPM<3:0>: Master Synchronous Serial Port Mode bits(3) '0010 = SPI Master mode: clock = FOSC/64 (1mhz) '0001 = SPI Master mode: clock = FOSC/16 (4mhz) '1010 = SPI Master mode: clock = FOSC/8 (8mhz at 64fosc) (10mhz at 80fosc) (12mhz at 96fosc) '0000 = SPI Master mode: clock = FOSC/4 (16mhz) (Doesn't Work!) 'Eusart 1 (64mhz FOSC) 'Serial/Video Comms (16mhz x 4) 'DEFINE HSER_RCSTA 90h 'Enable serial port & continuous receive 'DEFINE HSER_TXSTA 24h 'Enable transmit, BRGH = 1 'DEFINE HSER_CLROERR 1 'Clear overflow automatically 'DEFINE HSER_SPBRG 22 '57600 Baud @ 64MHz, -0.44% (277 Decimal = $115) 'define HSER_SPBRGH 1 'BAUDCON1.3 = 1 'Enable 16 bit baudrate generator ''Eusart 1 (80mhz FOSC) 'Serial/Video Comms (20mhz x 4) DEFINE HSER_RCSTA 90h 'Enable serial port & continuous receive DEFINE HSER_TXSTA 24h 'Enable transmit, BRGH = 1 DEFINE HSER_CLROERR 1 'Clear overflow automatically DEFINE HSER_SPBRG 90 '57600 Baud @ 80MHz, -0.064% (346 Decimal = $15A) define HSER_SPBRGH 1 BAUDCON1.3 = 1 'Enable 16 bit baudrate generator ''Eusart 1 (96mhz FOSC) 'Serial/Video Comms (24mhz x 4) 'DEFINE HSER_RCSTA 90h 'Enable serial port & continuous receive 'DEFINE HSER_TXSTA 24h 'Enable transmit, BRGH = 1 'DEFINE HSER_CLROERR 1 'Clear overflow automatically 'DEFINE HSER_SPBRG 160 '57600 Baud @ 96MHz, -0.080% (416 Decimal = $1A0) 'define HSER_SPBRGH 1 'BAUDCON1.3 = 1 'Enable 16 bit baudrate generator
