Faster SHIFTOUT without dedicated hardware, possible?
Results 1 to 20 of 20
    Aug 2011
    Default Re: Faster SHIFTOUT without dedicated hardware, possible?
    which PIC device are you using?
    looking at some old posts, this thread here http://www.picbasic.co.uk/forum/showthread.php?t=5568 has a number of issues.
    Just got to PC today and wanted to run your code, but I have a little problem, my current code looks like this:
    SHIFTOUT SDA, SCK, 0, [$C0+row,col]
    It sends 2 bytes in a row. How should I do the same with your code?
    Aug 2011
    Just send each byte individually... the result will be the same since SHIFTOUT really does it that way too.
    WREG = $C0 + row
    call SHOUT
    WREG = col
    call SHOUT
    If you're using a PIC16 then you'll have to add a definition for a WREG variable
    WREG var byte
    If you wanted to make the code the same for all devices then change all the references to WREG to a byte variable instead, including the SHOUT subroutine.
    Here I've named it SHDATA.
    SHDATA var byte
    SHDATA = $55
    call SHOUT
    Just tried this code and it works, thanks!
    But need to use it for shiftout 1 - MSBFIRST.
    What should be changed in it?
    Aug 2011
    For MSBFIRST, just change the order of the 'WREG.bit' tests
    ; SHOUT
    ; shift out 8 bits of data, MSB to LSB
    ; data clocked on rising edge of SHCLK
    ; WREG = data to send
    SHOUT:
    SHDAT = 0
    if WREG.7 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.6 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.5 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.4 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.3 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.2 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.1 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.0 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    Thank you again!
    Only today I managed to adapt this code to my hardware and it works very fast!
    But I have a question, WREG is not an variable, but a register name, right?
    Aug 2011
    You're right, for a PIC18 WREG is the name of a register.
    If you're using a PIC16 then you have to declare a variable named WREG as I mentioned in post #9
    WREG var byte
    SHDATA var byte
    SHDATA = $55
    call SHOUT
    It works fine without definition on PIC16F1828.
    In fact, if I add definition, compiler gives an error - Redefiniton of VAR
    This is why I asked
    Aug 2011
    If you're using an enhanced midrange PIC16 device (like the PIC16F1828) then it has a WREG, so it works with them too without having to declare a 'WREG' variable.
    It's only for the older PIC16's you'd have to define it, or just change all the references to WREG to a new variable name of your choice.
    The above code works fine with TM1629A display.
    But it does not work properly with APA102C leds.
    I have the following statement:
    SHIFTOUT di, ci, 1,[224+Bri[x],COLORS[X+16],COLORS[X+8],COLORS[X]]
    Which I have replaced with
    wreg=224+Bri[x]
    gosub shout
    wreg=COLORS[X+16]
    gosub shout
    wreg=COLORS[X+8]
    gosub shout
    wreg=COLORS[X]
    gosub shout
    The issue is that only odd bytes got transferred.
    Say if I set some value to 2 or 4 it gets delivered to LEDs, but if I set it to 1 or 3 or 5 - nothing happens.
    Tried to insert pause between each subroutine call - no difference
  1. Replies: 29
    Last Post: - 20th May 2010, 03:47
  2. Is there a faster way to compare?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th February 2010, 19:48
  3. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
  4. Is there a faster/better way of doing this?
    By Mad_Labs in forum mel PIC BASIC Pro
    Last Post: - 8th October 2005, 11:01
