Sleep does not really sleep...
Results 1 to 9 of 9
Threaded View
    Default Sleep does not really sleep...
    On a 16F886 the following code initially is in sleep mode having almost 0 current through PIC.
    But after first interrupt-on-change (port B), the sleep does not zero current. It stays rather high at 1,8 mA.
    Something is still on and cannot see what.
    #config
    Line1 = _DEBUG_OFF & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF
    Line2 = _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
        __CONFIG _CONFIG1, Line1 & Line2
        __CONFIG _CONFIG2, _WRT_OFF; & _BOR40V
    #endconfig
    OSCCON = %01110001 '8MHz Clock
    DEFINE OSC 8
    OPTION_REG.0=1		'PSA0 PRESCALER SELECT 1:1 TO 1:256
    OPTION_REG.1=1		'PSA1
    OPTION_REG.2=1		'PSA2
    OPTION_REG.3=1		'PRESCALER TO: 1->WDT, 0->TMR0
    OPTION_REG.4=0		'T0SE SOURCE EDGE 1->H TO L, 0->L TO H
    OPTION_REG.5=0		'T0CS 1->FROM RA4, 0->FROM INT. CLOCK
    OPTION_REG.6=0		'INT EDGE SELECT 0->H TO L, 1->L TO H
    OPTION_REG.7=0		'PULL UP 1->DISABLE, 0->ENABLE
    adcon0=%10111101    'ADC on, input set at Fixed Ref 0.6 Volts,adc clk @ Fosc/32
    adcon1=%10000000    'right justified
    ansel=$00
    anselh=$00
    DEFINE ADC_BITS 10          ; Set-up ADC for fast 10-bit results
    DEFINE ADC_SAMPLEUS 5
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_SPBRG 12  ' 9600 Baud @ 8MHz, 0,16%
    ccp1con=0
    PORTA=%00000000
    PORTB=%01111000
    PORTC=%11000000'%10000001
    TRISC = %10000000
    TRISA = %00000000			'PA0: buzzer out
    							'PA1:
    							'PA2:
    							'PA3:
    							'PA4:
    							'PA5:
    							'RA6:
    TRISB = %01111000			'PB0: col3 out
    							'PB1: col2 out
    							'PB2: col1 out
    							'PB3: line4 in
    							'PB4: line3 in
    							'PB5: line2 in
    							'PB6: line1 in
    							'PB7: N.C.
    clear
    'baudctl=%00010000    'Transmit inverted data (with no MAX232/USB2Serial needed)
    BAUDCTL = %00000000   'Transmit true data (with MAX232/USB2Serial needed)
    WPUB = %01111000
    IOCB = %01111000
    INTCON = %10001000
    wsave    var byte $70 system
    wsave1   var byte $a0 system
    wsave2   var byte $120 system
    wsave3   var byte $1a0 system
    a       var word
    pressed var byte
    buzzer  var portc.0
    char    var byte
    idx     var byte
    array   var byte[5]
    keyin   var byte
    ix      var byte
    '-------------   INTERRUPTS SETUP   ---------------------
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INT_LIST  macro;    IntSource,  Label,      Type,  ResetFlag?
        INT_Handler     RBC_INT,    _IOC2,      PBP,    yes
        ;INT_Handler     TMR1_INT,   _timer,     PBP,    yes
    @   INT_ENABLE  RBC_INT      ; Enable Port B on change
    ;@   INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    '*             Interrupt on Change
    IOC2:
        txsta=$20  'Enable USART
        rcsta=$90
        keyin=portb & %01111000     'End mismatch on port B interrupt
        'hserout [bin8 keyin,13,10]'check keyin
        if keyin<>120 then
            adcon0.0=1:adcon0.1=1 'Start adc for bat level check
            pressed=1  'Flag key press
            toggle buzzer
            pressed=0
    @ INT_RETURN
    portb=$78   'set port to 01111000
    txsta=0     'Turn off all peripherals
    rcsta=0     'before sleeping
    adcon0.0=0  'Disable ADC
    pressed=0   'reset flag pressed
    intcon.0=0  'reset RBIF flag
    t1con.0=0   'turn off timmer 1
    buzzer=0
    @ sleep
    @ nop
    hserout ["Alive",13,10]
    while adcon0.1:wend
    a.byte0=adresl:a.byte1=adresh
    if a>192 then
        hserout ["Bat low",dec3 a,13,10]
        hserout ["Bat ok",dec3 a,13,10]
    keyscan:
    while 1
        for ix=0 to 2     'scan columns
            portb=~dcd ix 'invert polarity
            if keyin<>120 then keycheck  'no key press,scan again
        next ix
    wend
    keycheck:
    ' 0,   1, 2, 3, 4, 5, 6,  7,  8,  9,  *,  #
    ' 117,59,61,62,91,93,94,107,109,110,115,118
        keyin=portb & 127
        lookdown keyin,[117,59,61,62,91,93,94,107,109,110,115,118],char
        if char>11 then keyscan 'wrong key,noise etc
        char=char+48
        hserout [char,13,10]
        array[idx]=char
        idx=idx+1
        if idx=5 then
            hserout [str array\5,13,10]
            idx=0
        pause 200
  1. Asm sleep - pbp sleep
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 18th May 2020, 22:13
  2. Can't @sleep
    By MOUNTAIN747 in forum General
    Last Post: - 30th December 2010, 18:29
  3. Trying to add a sleep function or pretend to sleep
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 9th May 2010, 20:10
  4. How to go to sleep
    Last Post: - 22nd September 2006, 19:38
  5. @sleep
    By jheissjr in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 23:42
