16Bit 125KHz PWM with PIC12F1572
Results 1 to 9 of 9
    Jul 2013
    Default 16Bit 125KHz PWM with PIC12F1572
    Hello,
    I am upgrading from a 16F628 to a 12F1572 to take advantage of it's "Precision" 16Bit PWM.
    How do I configure PBP 3 to take advantage of it's HWPWM function?
    (Needed is a symetrical 125KHz (4mS/4mS) 50% duty cycle.)
    ' 125KHz PWM Test Generator PIC16F628 For Planar Antenna Experiment
    ' 12LF1572 (12F1572 is the 5Volt Version)
    ' Jay Zebryk 2022-07-04
    __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _BOREN_ON & _CLKOUTEN_OFF
    __config _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_ON & _BORV_LO & _LPBOREN_OFF & _LVP_OFF
    ' CP_OFF changed to CP_ON to enable hardware PWM.
    ' See HPWM_F1579_NOTES.txt
    ' MCLRE_ON changed to MCLRE_OFF for digital input with Weak Pull-Up Enabled
    ' OLD SETTINGS FROM 16F628
    'PR2 = %00001001 ' dec 9 47.5%
    'T2CON = %00000101 ' dec 5
    'CCPR1L = %00000100 ' dec 4
    'CCP1CON = %00111100 ' dec 60
    WPUA = %00000100 ' Weak Pull-Up Enabled RA2 (SW Input)
    OSCCON = %01111000 ' Bits 6-3 16 MHz OSC, Internal, I/O Pins Enabled
    Define OSC 16
    DEFINE CCP1_REG PORTA ; Tell PBP which pins the CCP outputs are on
    DEFINE CCP1_BIT 2
    Beep VAR PORTA.0 ' Assign name Beep (and/or Piezoto PORTB.0
    TX var TRISA.1 ' 125KHz PWM Output (CCP1 Pin)
    SW var TRISA.2 ' CW vs 100mS ON / 900mS OFF
    PortA = %00000000 ' PortA all OFF
    TRISA = %11111100 ' Inputs = 1, Outputs = 0
    I VAR BYTE ' Index I
    CLEAR ' Clear all variables to 0
    Boot:
    Pause 1000
    For I = 0 to 1
    Beep = 1
    Pause 100
    Beep = 0
    Next I
    ' THE BELOW PRODUCES A COMPILATIO ERROR
    HPWM 1, Duty, 125000 ' Start HWPWM CONTINUOUS
    Beep = 1
    Beep = 0
    goto Main
    Default Re: 16Bit 125KHz PWM with PIC12F1572
    125KHz is only available with a pbpl compile
    from the manual hpwm section
    Frequency is the desired frequency of the PWM signal. On devices with 2 channels,
    the Frequency must be the same on both channels. Not all frequencies are available
    at all oscillator settings. For the non-long versions of PBP (PBP and PBPW),
    the highest frequency at any oscillator speed is 32767Hz.
    every chip you have posted about on this subject is quite capable of that output.
    your posted code has never been correctly setup to achieve that goal.
    you have never acknowledged anybody's code corrections or explanation to achieve your goal,
    you have never indicated that you have even tried them out .
    Jul 2013
    FYI:
    1. I just requested a current PBP manual to see if the HWPWM feature now includes >32767Hz.
    2. I have the PIC12F1572 data sheet which seems to have a completely differenct PWM operation than the 16F628.
    3. I did try and test your suggestions for the 16F628 which worked except for the symetrical issue.
    Below is the App so far with Zero progress on the PWM.
    All it will do is modulate an 125KHz magnetic antenna using OOK.
    Currently, I have configured the internal OSC for 16MHz.
    I do not know whether the 4X PLL is required for a perfectly symetrical On/Off Duty Cycle of 4uS On / 4uS Off.
    Peace,
    what did you try , post your code
    all those calc's are for a 20MHz clock if you use a different OSC then they must be recalculated
    the internal OSC is not brilliantly accurate and could need trimming to approximate a symmetrical output
    on paper these settings are incorrect for 16 or 20 MHz
    Aug 2011
    That's probably because you're setting the CCP1CON CCP1X and CCP1Y bits, which control the duty cycle lsb's.
    Clear those two bits (ie CCP1CON = $0C for PWM mode).
    You should be able to get 125KHz with a 50/50 duty cycle at either 16MHz or 20MHz. You don't need 16-bit PWM for that.
    OK
    The 16-bit PWM Module in the PIC12F1572 takes cues from the 16-bit Output Compare (OC) Module. There are several FRMs that cover the dsPIC33 OC functions if you want a more elaborate explanation. If your PWM Clock is 4 MHz (Fosc/4 @ 16 MHz), each tick takes 0.000 000 250 seconds; or 0.25 uS. For 125 kHz, you need your Period to last for 32 Clock cycles. Unfortunately, that will be your resolution -- 0 >> 31. You cannot get 16-bit resolution -- or anywhere near that. Even setting Fosc to 32 MHz, yielding an 8 MHz Fosc/4, max resolution is still only 0 >> 63. The fastest PWM frequency with 16-bit resolution will be around 122 Hz (not kHz, just Hz). I had considered using this PIC for a previous project and decided to use a dsPIC33 instead, as I couldn't get a fast enough frequency out of the PIC12F1572.
  1. 125KHz HW PWM Output
    By Zebryk in forum mel PIC BASIC Pro
    Last Post: - 28th June 2022, 01:56
  2. Replies: 4
    Last Post: - 13th April 2022, 08:33
  3. PBP for dsPIC 16bit??
    By photoelectric in forum PBP Wish List
    Last Post: - 9th July 2014, 08:13
  4. Replies: 1
    Last Post: - 4th March 2013, 21:57
  5. Replies: 3
    Last Post: - 12th March 2008, 05:33
