PWPS Servo Problem
Results 1 to 11 of 11
    Default Re: PWPS Servo Problem
    I tested the PIC12F1840 and PIC16F1824 with software serial input. PIC frequency set to 8MHz as required PBP at 9600 baud.
    It's working, but the response is kinda slow.
    '*  Notes   : PIC16F1824                                        *
      __config  _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
      __config  _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_19 & _LVP_OFF
    DEFINE OSC 8     ; Use a 8 MHZ internal clock
    OSCCON = %01110000
    ANSELA  = 0
    ANSELC  = 0
    TRISA = %000000
    TRISC = %00100001 ; PORT C.5 input RX, C.0 safety, rest output
    CM1CON0 = 0       ; Disable comparator 1
    CM2CON0 = 0       ; Disable comparator 2
    OPTION_REG.7=1    ; Disable weak pull ups
    APFCON0.7=0
    APFCON0.2=0
    ; def_ports:
    PWPSpin       var portc.1  ; servo signal OUTPUT (must be defined before PWPS_Servo.INC)
    safety        var portc.0  ; safety leash magnetic switch
    ; def_vars:
    n             var byte
    cmd           var byte
    ; def ext libr:
    include "PWPS_Servo.INC"                    ; Software Servo PWM module
    include "modedefs.bas"                         ; modedefs must be after PWPS_Servo.INC otherwise it doesn't work
    init:                                       ; vars start values
    position      = 1
    cmd           = 245
    n             = 0
    gosub StartPWPS                             ; start PWPS module
    Serin2 portc.5,84,20,lost, [wait("Q"),dec cmd]         ; wait for Q and then for CMD
    if cmd = 155 then                           ; increment servoimpulse
    Position=Position+1
    if Position > 1199 then Position = 1200     ; max servoimpulse lenght 2us
    gosub SetPWPS
    if cmd = 145 then                           ; decrement servoimpulse
    Position=Position-1
    if Position < 1 then Position = 1           ; min servoimpulse lenght 1us
    gosub SetPWPS
    n=n+1                                       ; long press decrement
    if n=255 then                               ; switch to minimum servoimpulse after cca. 3. sec.
    position=1
    if cmd = 245 then                            ; if transmitter is switched OFF servoimpulse to nimimum
    Position=1
    gosub SetPWPS
    if safety = 1 then                           ; if safety switch is OFF servoimpulse to nimimum
    Position=1
    gosub SetPWPS
    lost:
    n=0                                           ; clear long press counter value to 0
    Position=1
    gosub SetPWPS
    Then I tested even only the PWPS run alone on PIC16F1824 and via serial terminal from PC sent a serial command and the PIC freezes.
    Then I tested what if I stop TMR1 (of course PWPS stopped working) but the HW usart works without problems.
    Something is wrong with this PWPS include but I can't figure out what.
    how sure are you that your code is compiled with the modified inc as i suggested ?
    if you examine the lst file generated and search for NoTimerInt
    do you see
    Name:  Screenshot 2022-07-06 104811.jpg
    pbp can be tricky if multiple versions of inc files exist, sometimes the "wrong" version can be used inadvertently
  1. servo/motor problem
    By griffin in forum mel PIC BASIC
    Last Post: - 10th February 2009, 20:07
  2. Servo motor problem
    By dboy in forum mel PIC BASIC Pro
    Last Post: - 20th September 2008, 15:54
  3. servo driver problem
    By al000y in forum mel PIC BASIC Pro
    Last Post: - 7th February 2007, 10:17
  4. Servo Pulser problem
    Last Post: - 24th January 2007, 12:48
  5. servo pulse problem...
    By tonkgang in forum mel PIC BASIC Pro
    Last Post: - 7th April 2006, 16:12
