NTC resistor
Results 1 to 11 of 11
Thread: NTC resistor
    Default NTC resistor
    Does somebody already made something with a NTC in it.
    I like to build a NTC controlled fan circuit, but need a schematic and source to read a 47 KOhm NTC resistor.
    I gave up on this approach and used a digital temp sensor instead. A lot less hassle.
    Jun 2005
    Post
    NL2TTL,
    What pic are you using?
    I use a 10K NTC thermistor, 10K fixed resistor voltage divider connected to an analog input on a 16F819. I get approximately 6 counts per degree F resolution.
    I also use the hardware PWM to control 400 watts of fan motors based on temperature.
    I also recommend Darrel Taylor's averaging routine. It works great!
    http://www.pbpgroup.com/modules/wfse...hp?articleid=7
    Mark
    I'm using a NTC because the costs are lower, and the PIC i'm using is a 16F877.
    Jun 2005
    NL2TTL,
    What are you trying to acheive?
    What temperature range are you planning to control?
    Do you plan on using PWM?
    35 degrees C Off
    40 degrees C 50% duty factor
    45 degrees C 70% duty factor
    50 degrees C 70% duty factor
    65 degrees C 100% duty factor
    Mark
    yes something like that, only a resistor (NTC) is not liniar so to compensate that you have to use a formula.
    Why not have a look at AN685 from Microchip. It's about Thermistors in Single Supply Temperature Sensing Circuits.
    Jun 2005
    Post
    NL2TTL,
    Try these 2 routines;
    This is how I read A/D converters with 10 bits resolution (0 - 1023)
    The average routine is Darrel Taylor's averaging routine followed
    by a simple linearization.
    ReadAD: ' Read A/D converters with 10 bits resolution (0 - 1023)
    ADCIN 0,AD0 'read channel 0...AN0
    VALUE = AD0 >> 6
    Sensor = 0
    gosub Average
    AD0 = VALUE
    ADCIN 1,AD1 'read channel 1...AN1
    VALUE = AD1 >> 6
    Sensor = 1
    gosub Average
    AD1 = VALUE
    ADCIN 2,AD2 'read channel 2...AN2
    VALUE = AD2 >> 6
    Sensor = 2
    gosub Average
    AD2 = VALUE
    ADCIN 3,AD3 'read channel 3...AN3
    VALUE = AD3 >> 6
    Sensor = 3
    gosub Average
    AD3 = VALUE
    ADCIN 4,AD4 'read channel 3...AN4
    VALUE = AD4 >> 6
    Sensor = 4
    gosub Average
    AD4 = VALUE
    Average: ' Average Analog values -=-=-=-=-=-=-=-=-=-=
    IF Value = ADavg[Sensor] Then NoChange
    IF ABS (Value - ADavg[Sensor]) > FAspread OR Value < AvgCount Then FastAvg
    IF ABS (Value - ADavg[Sensor]) < AvgCount Then RealClose
    ADavg[Sensor] = ADavg[Sensor] - (ADavg[Sensor]/AvgCount)
    ADavg[Sensor] = ADavg[Sensor] + (Value/AvgCount)
    GoTo AVGok
    FastAvg:
    ADavg[Sensor] = Value
    GoTo AVGok
    RealClose:
    ADavg[Sensor] = ADavg[Sensor] - (ADavg[Sensor]/(AvgCount/4))
    ADavg[Sensor] = ADavg[Sensor] + (Value/(AvgCount/4))
    AVGok:
    Value = ADavg[Sensor] ' Put Average back into Value
    NoChange:
    if AD0 >= 435 then RA = 66 'thermistor linearization
    if AD0 >= 446 then RA = 67
    if AD0 >= 450 then RA = 68
    if AD0 >= 456 then RA = 69
    if AD0 >= 461 then RA = 70
    if AD0 >= 477 then RA = 71
    if AD0 >= 473 then RA = 72
    if AD0 >= 479 then RA = 73
    if AD0 >= 486 then RA = 74
    if AD0 >= 492 then RA = 75
    if AD0 >= 499 then RA = 76
    if AD0 >= 506 then RA = 77
    if AD0 >= 513 then RA = 78
    if AD0 >= 519 then RA = 79
    if AD0 >= 526 then RA = 80
    if AD0 >= 529 then RA = 81
    if AD0 >= 535 then RA = 82
    if AD0 >= 544 then RA = 83
    if AD0 >= 548 then RA = 84
    if AD0 >= 552 then RA = 85
    if AD0 <= 438 then RA = 59
    if AD0 >= 562 then RA = 58
    This is how I determine my fan speed. In my case the minimum Fan speed is
    60%.
    IF RA <= SETPOINT Then cbs
    ERROR = (RA - Setpoint )
    IF ERROR <= 2 then FANSPEED = 153 '60%
    IF ERROR >= 3 then FANSPEED = 178 '70%
    IF ERROR >= 5 then FANSPEED = 204 '80%
    IF ERROR >= 7 then FANSPEED = 229 '90%
    IF ERROR >= 9 then FANSPEED = 255 '100%
    CASE 2
    cbs: FANSPEED = 153 ' manual spd 1
    CASE 3
    FANSPEED = 204
    case 4
    FANSPEED = 255
    end select
    IF FANSPEED > SPD + 50 THEN SPD = SPD + 2 'softstart or slowly
    IF FANSPEED > SPD THEN SPD = SPD + 1 'change speed
    'IF FANSPEED < SPD + 50 THEN SPD = SPD - 10
    IF FANSPEED < SPD THEN SPD = SPD - 1
    hpwm 2,SPD,32767 ' PWM 32 KHz
    I hope this helps get you started.
    Mark
    I requisted a few digital samples by maxim, and gonne try it with those.
    Because the failure is mutch lower, thanks for al the replys
    Which ones are you getting from Maxim?
    Maniac's Avatar
    Maniac Guest
    Hello
    I got exited to see the code Mark posted. I am in the process of building a controller. It will need to cycle between 2 temperatures using a thermistor and a small heater. Did anyone have built something similar using a PIC?
    Attila
  1. MCLR resistor
    Last Post: - 5th November 2007, 17:01
  2. resistor in parallel with a thermistor
    By Pic_User in forum General
    Last Post: - 13th March 2007, 02:42
  3. Reading A Photo Resistor using ADC
    Last Post: - 25th January 2007, 10:28
  4. Replies: 5
    Last Post: - 2nd March 2006, 10:21
  5. Do I need that Resistor with my LCD?
    Last Post: - 15th July 2004, 11:50
