Data processing in array
Results 1 to 13 of 13
    Default Data processing in array
    There is an array of n elements. Each element stored the pulse width from a PulsIn. Then according to pulse width, the bit_array bit will be 0 or 1. But if it is out of range then a new data set will be collected.
    If the byte_array(x) is between a and b then bit_array.0(x)=0
    If the byte_array(x) is between c and d then bit_array.0(x)=1
    if complete n elements then continue, else goto parse new byte_array data.
    Seems easy but could not find a way to exit the loop!
    Any help please?
    parse byte_array
    find_bit:
                if byte_array[index]>145 then    '>725ìs
                    if byte_array[index]<180 then
                        bit_array.0[index]=0
                        index=index+1
                        if index<n then find_bit
                if byte_array[index]<100 then    '>725ìs
                    if byte_array[index]>75 then
                        bit_array.0[index]=1
                        index=index+1
    Default Re: Data processing in array
    i would do it this way
     sample_data var byte[32]
    fail var bit
     sample var byte
     a_one  var byte
     a_zero var byte
     result var byte[4]
     tolerance var byte
        tolerance = 20
        a_one = 160  ; mean value of a one bit
        a_zero = 90   ; mean value of a zero bit
    clear_result:
        result[0] = 0
        result[1] = 0
        result[2] = 0
        result[3] = 0
    get_result:
        sample = 32
        fail = 0
        while sample && ! fail
            sample = sample-1
            if   (abs(sample_data[sample] - a_one)< tolerance ) then
               result.0[sample] = 1
                if  (abs(sample_data[sample] - a_zero)> tolerance ) then fail = 1
        wend
        if fail then
            result bad
            break out the champagne
    Thanks Richard.
    Makes sense though kinda heavy in respect of calculations.
    2 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    maybe but it has positive indication of failure , it ceases testing on failure and it actually detects failures.
    i would not be quibbling over a few words of code space when the entire process of encoding the bit stream into an unnecessary byte array
    of times instead of directly into a bit array on detection would be heaps more efficient.
    if the correct conditions can be met the pbp abs command can substituted for byte results like below
    failure detection comparison
    'parse byte_array define OSC 8
     bit_array var byte[4]
     byte_array var byte[32]
     arraywrite  byte_array,[80,80,160,80,80,160,80,160,_
                             80,160,80,80,160,80,80,160,_
                             160,80,80,80,80,160,160,80,_
                             80,80,80,160,80,110,160,160]
     n           var byte
     index      var byte
     trisa.1 =0
     porta=2
     serout2 porta.1 ,84 ,["ready",13]
     n = 32
     index = 0
    find_bit:
                        index=index+1
                        index=index+1
     serout2 porta.1 ,84 ,[bin8 bit_array[3], bin8 bit_array[2], _
                             bin8 bit_array[1], bin8 bit_array[0],13]
     ;my way
        tolerance con 20
        a_one con 90  ; mean value of a one bit
        a_zero con 160   ; mean value of a zero bit
        fail var bit
    clear_result:
        bit_array[0] = 0
        bit_array[1] = 0
        bit_array[2] = 0
        bit_array[3] = 0
    get_result:
        n = 32
        fail = 0
        while n && (!fail)
            n = n-1
            index = byte_array[n] - a_one;    bytewise abs shortcut
            if index.7 then index = ~index+1;    bytewise abs shortcut
            if   index <tolerance  then  ;     (abs(byte_array[n] - a_one))  < tolerance
               bit_array.0[n] = 1
             index = byte_array[n] - a_zero ;    bytewise abs shortcut
            if index.7 then index = ~index+1 ;    bytewise abs shortcut
                if  index   then fail = 1   ;(abs(byte_array[n] - a_zero))>tolerance
            serout2 porta.1 ,84 ,["."]
        wend
        if fail then
           serout2 porta.1 ,84 ,[13,"fail",13]
            serout2 porta.1 ,84 ,[13,bin8 bit_array[3], bin8 bit_array[2], _
    result of sim
    Name:  Screenshot 2022-06-04 110905.jpg
    ...when the entire process of encoding the bit stream into an unnecessary byte array
    of times instead of directly into a bit array on detection would be heaps more efficient...
    Sure I agree but could not find a fast way to encode directly the PWM bit stream into bits. The bits are coming from an RF radio receiver and have the typical 66-bit format of a keeloq transmission: 16ms guard time (low), 12 bits of 400us/400us as preamble, a 3-4ms low header and then the 66 bits of the data.
    My routine to receive all these bits is based on the PulsIn command in a while-wend loop:
    code        VAR byte[9] BANK0   ' PWM read in
    code1       var byte[66]            ' Keeloq bits to be decrypted
    KEY_0       var byte BANK0
    KEY_1       var byte BANK0
    KEY_2       VAR BYTE BANK0
    KEY_3       VAR BYTE BANK0
    KEY_4       VAR BYTE BANK0
    KEY_5       VAR BYTE BANK0
    KEY_6       VAR BYTE BANK0
    KEY_7       VAR BYTE BANK0
    mask        VAR BYTE BANK0
    CSR_0       VAR BYTE BANK0
    CSR_1       VAR BYTE BANK0
    CSR_2       VAR BYTE BANK0
    CSR_3       VAR BYTE BANK0
    pass        VAR BYTE BANK0
    CNT1        VAR BYTE BANK0
    CNT2        VAR BYTE BANK0
    temp        var word
    OVER:
    while 1
    index=0
    guard:
        pulsin portb.0,0,temp     'find header of 16ms
        if temp<2500 then main   ' PIC is clocked at 8MHz, so a PulsIn step is 5usec.
        if temp>4400 then main   ' 5usec x 2500= 12.5ms up to 5usec x 4400=22ms
    preamp:
        pulsin portb.0,1,temp     'then skip 12 pulses of 50% Duty, 400usec
        if temp<50 then main
        if temp>90 then main
        index=index+1
        if index<11 then preamp
        index=0
    pulsetrain:                   'now collect 66 pulses ~800/400 usec
        pulsin portb.0,1,code1[index]
        index=index+1
        if index<66 then pulsetrain
        index=0
    find_code:  'convert pulse width to binary 66 bit stream
                if code1[index]>130 then
                    if code1[index]<170 then
                        code.0[index]=0
                if code1[index]<80 then
                    if code1[index]>55 then
                        code.0[index]=1
                index=index+1
                if index<66 then find_code
                'Display the encrypted and decrypted array
                hserout ["Rec: ",bin2 code[8]," ",bin8 code[7]," ",bin8 code[6]," ",bin8 code[5]," ",bin8 code[4],":",bin8 code[3]," ",bin8 code[2]," ",hex2 code[1]," ",hex2 code[0],13,10]  'display pulse train
                CSR_0=CODE[0]:CSR_1=CODE[1]:CSR_2=CODE[2]:CSR_3=CODE[3]
                GOSUB DECRYPT_K
                hserout ["Dec: ",bin2 code[8]," ",bin8 code[7]," ",bin8 code[6]," ",bin8 code[5]," ",bin8 code[4],":",bin8 CSR_3," ",bin8 CSR_2," ",hex2 CSR_1," ",hex2 CSR_0,13,10,13,10]
    wend
    Obviously, cannot show the DECRYPT_K routine... Sorry.
    The above code is not near your fail safe program and will try to fit in the code space after a clean up of the rest code.
    The more I observe your code and way of thinking, the more I see its briliance.
    Thank you again Richard,
    a couple of ways
    pulsetrain:
    index=67
    while index
    while  !portb.0 :wend   ;wait for hi
    index=index-1
    pauseus 600                  ;bit period=3*te ie 3*400=1200uS
    code.0[index]= ~ portb.0      ;sample @midpoint of bit period
    while  portb.0 :wend    ;wait for lo
    wend
    ;or with some simple time supervision
    fail var bit
    timer var word ext
    @timer = TMR1L
    PRELOAD CON 65535-820  ;@8MHz  timer prediv 2  each tick=1uS
    pulsetrain:
    index=67
    t1con=0
    fail=0
    while index
    timer=preload
    t1con=$21
    index=index-1
    while  portb.0 && !pir1.0 :wend    ;wait for lo
    t1con=0
    fail=fail | pir1.0
    wend
    or sample @50,250,450,650,850 uS past transition to hi
    where valid result is
    11000 for a 1
    11110 for a 0
    there are endless methods
    My simple thinking lead me to this version ditching the big array:
        index=0
    pulsetrain:                   'now collect 66 pulses ~800/400 ìsec
        pulsin portb.0,1,temp1
        if temp1<55 then main
        if temp1>170 then main
        if temp1<130 then
            code.0[index]=1
            code.0[index]=0
        index=index+1
    And then came your masterpiece of coding with TMR1...! Amazing!
    It just needs to be reversed (the code array) I guess. No big deal.
    In a noisy environment you can over sample a bit to be sure of data validity, i expect the serial data from a keeloq
    chip to be quite clean so a single sample point would suffice
    11000 for a 1
    11110 for a 0
    sample var bitfail var bit
    fail=0
    pulsetrain:
    index=67
    while index && !fail
    pauseus 50               ;50
    if   !portb.0 then  fail = fail | 1
    pauseus 200              ;250
    pauseus 200              ;450
    sample=portb.0
    pauseus 200               ;650
    if   portb.0^sample then  fail = fail | 1
    pauseus 200               ;850
    if   portb.0 then  fail = fail | 1
    index=index-1
    code.0[index]= !sample
    wend
    In general the data stream on a good signal level is very clean. But when there is no RF signal, the radio module will produce a lot of noise that is converted to random pulses through the data slicer. This creates a lot of bad data and false triggers on a non rolling code systems if digital filtering is not applied. With the keeloq encryption it is safe to assume that such triggers will not happen. The probability to have 66 bits in a correct timing and also in the correct sequence, not mentioning the other safety measures of keeloq like counter etc, is really low if not zero.
    When you referred to 5 sampling points I was thinking of timers etc to maintain a fixed sampling point in time...
    Your code showed the application of KISS in a fine way!
    Thank you for your great ideas,
    i would not expect to ever receive a malformed bit from a keeloq serial stream , the data may be useless however.
    single point sampling should be ok imho
    Agree.
    Though I have checked various implementations of RF remote controls and many have wide tolerances from the specified timings.
    I am very much sure that those chips are bad copies of the original Microchip one. But are out there... If interested, I have many test of original and copy chips with the timings in excel file.
  1. Using Processing to display data graphs
    By ScaleRobotics in forum Off Topic
    Last Post: - 26th November 2016, 05:16
  2. How to get ASCII data in array.
    By Ioannis in forum Serial
    Last Post: - 6th November 2008, 20:14
  3. Filling pdu array with gps data!
    By camolas in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 00:54
  4. Data logger clock and array
    By PicLearner in forum mel PIC BASIC Pro
    Last Post: - 25th September 2008, 04:19
  5. Array data being corrupted
    By caverman in forum mel PIC BASIC Pro
    Last Post: - 17th March 2006, 04:22
