Hello members
PIC18F67K40
i try to operate timer1 without gate control.
seams it don't work.(timer0 work perfect).
i use 48mhz internal osc
i don't know what is wrong
Code:PIE4.0=1 'TMR1 Overflow Interrupt Enable bit INTCON.6=1 'Peripheral Interrupt Enable bit TMR1CLK=%00000001 'Timer1 Clock Source Selection Register Fosc/4 'TMR1CLK=%00000011 'Timer1 Clock Source Selection Register HFINTOSC ;TMR1GATE= T1GCON.7=0 'Timer Gate Enable bit T1CON=00110100 'Timer1 Prescale 8 , Do not synchronize external clock input & off ;T1CON=00110000 'Timer1 Prescale 8 , Synchronize external clock input with system clock & off PIR4.0=0 'CLEAR INT TIMER1 '****** TEST TIMER1 ******* T1CON.0=1 'TIMER 1 ON WAIT2: IF PIR4.0 THEN 'Timer1 INT T1CON.0=0 'Timer1 Off PIR4.0=0 'CLEAR INT PORTE.5=PORTE.5 ^ 1 'led on/off TEMP=35536 '20MS /8 48MHZ TMR1H=TEMP.BYTE1 TMR1L=TEMP.BYTE0 T1CON.0=1 'TIMER 1 ON ENDIF GOTO WAIT2 '************************
