Parsing commands and parameters
Results 1 to 5 of 5
    Default Parsing commands and parameters
    The project involves an arithmetic keyboard (0-9,*,#) on a device that has a module that can be programmed with parameters.
    In fact it is a portable transmitter with a module programmable with power level, frequency etc.
    My PIC is the good ol' F886 and since it has 8K of flash I d'rather not spend it with if-then tests.
    I would like to have an efficient way for the user to enter commands and parameters for example like this:
    *10
    responds with a beep
    434925
    I know this can be done with lots of if-then or select case but maybe there is a better way.
    Default Re: Parsing commands and parameters
    ask yourself
    what is the biggest command sequence that will be input ?
    how does the pic know when the input seq is complete ?
    when you know those answers then the answer will be obvious
    The commands following the * will not be more than 99 so * and two digits for the commands.
    The parameters are max 6.
    Once Melanie had posted a similar example for rs232 communication but has its limits.
    so a command is *99 or *9 or *09 [where 9 == a numeric digit]
    and a parameter is 9 up to 999999
    how do you signal that the command has been input and the parameter begins
    i would be tempted to use the # as enter
    so cmd 33 p2010 would be
    *33#2100#
    you will need to establish a method to cope with numbers bigger than a word
    you need a method first then code it
    For a more compact and maybe easier to code the command and data be at defined length.
    So command 9 would be 09 and data 9 (this is extreme but for the sake of discussion) would be 00009.
    So there is no need for extra termination character.
    Also I think word or long variable may not be helpful here. Better an array, since the data are distinct in meaning so a 433925 would mean 433,925MHz in reality as an absolute value.
    The beeps would help user to step with confidence entering the commands and data.
    I think stuffing an array and then select case is the way to do it.
  1. Serin parameters ??
    By Rony in forum General
    Last Post: - 21st August 2011, 18:01
  2. dc motor parameters
    By iugmoh in forum Off Topic
    Last Post: - 10th October 2009, 19:32
  3. DC motor parameters ?
    Last Post: - 28th June 2008, 10:46
  4. MCSP Bootloader Parameters
    By CocaColaKid in forum General
    Last Post: - 19th September 2005, 18:15
  5. @ Device Parameters
    By Randy_Suwanee in forum General
    Last Post: - 11th August 2004, 14:40
