Adding and reading byte variable from the bit array?
Results 1 to 7 of 7
    Default Re: Adding and reading byte variable from the bit array?
    Have you tried something like this?
    Myword2.5 = Mybyte1.2          'move bit 2 of Mybyte1 to bit 5 Myword2
    Myword2.6 = Mybyte1.3
    Myword2.7 = Mybyte1.4
    Myword2.8 = Mybyte1.5
    The issue is that these boundaries should be changeable, since different chars will have different pixel width.
    There are two ways of doing this - all capitals have same width and all non-capital letters have another, smaller width. This indeed reduces some visual gaps, but not exactly what I want.
    So my idea is to have a spare, "mask" byte for each character, which will define it's width and entry and exit points.
    Say, there's "t", it is 4 pixels wide, and "mask" for it will look like this 00011110. zeros will be trimmed, and bits #5,4,3,2,1 from the letter shape will be added to output image.
    Another, more complex idea, is to do it "ZX Spectrum way", via complex STR/MID/LEN/ASC and other statements, currently not implemented, but still doable, in PBP....
    FOR X=1 to 5
    Y=Z.X
    NEXT
    As I understand, such operation is not possible in PBP, I mean, it is not possible to substitute variable as a bit part identifier for another variable?
    where did you get that idea, it is very possible with the correct syntax
    suggest a read of the manual re
    Applying Offsets to Bits within a Variable or Register
    I didn't get the idea, I just tried it and it gives syntax error......
  1. Checking Bit of a Byte using another variable
    Last Post: - 12th December 2010, 15:02
  2. adding new word variable ?
    By iugmoh in forum General
    Last Post: - 21st February 2008, 00:26
  3. Setting / resetting a variable bit within a byte
    Last Post: - 9th February 2008, 18:38
  4. Bit/Byte array for Hserin/Hserout
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 1st September 2006, 23:07
  5. Word array behaving like byte array.... wierd
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 15:43
