Simplest way to write to USB stick or TF/SD card with PBP?
Results 1 to 16 of 16
    Default Re: Simplest way to write to USB stick or TF/SD card with PBP?
    Well there are several solutions capable of doing this. FTDI has this: https://www.ftdichip.com/old2020/Products/ICs/VNC2.htm
    I've bought ones made by Parallax back in 2011, and they were around $45 ea now prices are about 8 times lower...
    Miami, Florida USA
    I had a PBP project to write to a SD card and it worked. That was many years ago and I don't remember the details of it, but it works. Attached is the sample code that I downloaded from the internet. Just change the file extension to PBP or copy paste the code into your program.
    sdfs3.zipsdfs3.zip
    Anonymous
    2 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    For data logging type applications I've had great success with the OpenLOG. Just send it ASCII data over a UART line and it will write it to a .txt file on an microSD card.
    Thanks!
    Any sample PBP code?
    for OpenLOG ?
    Again, for simple datalogging type applications there's really no need for any sample code. Just send it ASCII data over a UART line and it will write it to a .txt file on a microSD card. It CAN do more than that if needed, I suggest you read the documentation. Sparkfun (who I believe created (and should have all the credit) the OpenLOG) have a tutorial but I'm sure you've found that already...
    Their tutorial is quite weird.
    I do need additional hardware or can hook it to say PIC16F886 directly?
    Also, about Baudrate and other init options, it is not clear I need to do it each time on power up or just once?
    No extra hardware needed.
    The easiest way is to put a config.txt, containing your desired options, on the SD card. See the Configuration File section of the tutorial.
  1. PBP registration does not stick, still unregistered
    By Heckler in forum FAQ - Frequently Asked Questions
    Last Post: - 28th June 2017, 06:04
  2. Replies: 0
    Last Post: - 6th March 2009, 08:52
  3. simplest usb bootloader pbc solution ??
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 12th December 2007, 17:09
  4. Replies: 9
    Last Post: - 10th April 2007, 20:22
  5. USB memory stick
    By Demon in forum mel PIC BASIC Pro
    Last Post: - 12th July 2005, 21:57
