BPI-216 Serial LCD module
Results 1 to 12 of 12
    Jun 2005
    Wisconsin
    If you have windows you could use hyper terminal or you could utilize someone elses lcd application.
    Crematory
    For best performance, connect your LCD to your chosen PIC in 8-bit Data mode, and use a PIC with a hardware USART onboard. You can pick up byte at a time from the receive register and immediately output to LCD. The PICs DATASHEET gives explicit instructions on how to drive the USART. I would not use HSERIN, and certainly not any of the software options like SERIN or SERIN2 etc. Since the timing is not critical for anything other than the USART, pick a Baudrate friendly xtal (like 22.1184MHz or 11.0592MHz) that gives zero errors at the popular baudrates. You should easily handle at least 56kb using this method (not that your LCD would be able to sensibly display that fast - it'll handle it, you just won't see it!).
    Melanie
    PS. I've mentioned before I don't do off-list requests.
    Jul 2005
    Thumbs up
    Thank you all very much for the comments you said, that really made me sure that this was the same problem I discovered today in deed.
    I have used this way:
    [Quote]
    RECEIVE:
    SERIN PORTA.2,N9600,RCVBYTE
    LCDOUT RCVBYTE
    GOTO RECEIVE
    [/qoute]
    And that worked perfectly after I discovered that I had to do two things:
    1. Increase the DATAUS and COMMANDUS at the receiving PIC which drives the LCD.
    2. Use the CHAR_PACING to 1700us for 9600 baud rate on the sending PIC part as darrel already told me.
    I noticed that scott edwards used faster LCDs than I do, so the user did not have to use CHAR_PACING delay at all, while scott took care of that at the LCD PIC part to overcome any slowy in the LCDs he used. Also I noticed that baud rates of 2400 will not require any CHAR_PACING and less DATAUS and COMMANDUS delay than 9600 baud rates because slower clocks can be used, its only the 9600 baud rate that needed some CHAR_PACING delay as it was 8MHz resonator. Any way I succeeded to send data at 9600 baud rates by reducing the DATAUS and COMMANDUS to 275 and 1750 respectively, but that was too risky.
    I was wondering how did scott edwards achieved baud rates of 9600 at 480KHz resonator clock !! I think he used pure assembly to immitate serin commands, and that was really kinda wise thing to do...
    But now I know from melanie's reply that using UART module will heal all the problems and let me discard the DATAUS, COMMANDUS, and CHAR_PACING when used...I will try to do that that and post the final code so guys won't have to buy serial LCDs any more
    Thanks all
    moud_man's Avatar
    moud_man Guest
    Default a question
    hi
    i saw in this thread that Darrel Taylor said"
    "If you have windows you could use hyper terminal "
    so can you expain briefly how can i use the hyper terminal to connwct to the pic? i know that hyper terminAL is used to connect 2 computers but with pic idonot know
    thnx for reading
    bye
    Jul 2005
    Quote Originally Posted by moud_man
    hi
    thnx for reading
    bye
    I have used a piece of VB6 code to immitate the Serout command...
    moud_man's Avatar
    moud_man Guest
    Default what are you saying??!
    i donot understand anything but,
    thanl you for reply
    bye
    DATAUS and COMMANDUS are LCD defines used to ensure correct LCD data and command timing are are nothing to do whether you use the USART or not.
  1. LCD serial backpacks
    By Archangel in forum Serial
    Last Post: - 30th December 2010, 05:51
  2. Parallax Serial LCD and issues
    By nbrucew in forum mel PIC BASIC
    Last Post: - 18th September 2009, 05:42
  3. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  4. PIC16F684 + 8*2 LCD module
    Last Post: - 6th March 2008, 00:38
  5. Serial LCD
    Last Post: - 15th November 2007, 09:31
