BPI-216 Serial LCD module
Results 1 to 12 of 12
    Jul 2005
    Question BPI-216 Serial LCD module
    Hi
    I was wondering if any one has tried to make his own serial LCD interface like BPI-216 serial LCD module.
    I need to know how I can do that in deed.
    SERIN
    LCDOUT
    Imagination not required.
    Jun 2005
    Wisconsin
    I'm with Darrel Taylor on this. I created a serial to VFD interface once.
    Grab the datasheet for the LCD in one hand and the datasheet for the serial LCD you are modeling and start programming.
    Jul 2005
    Smile
    Thanks guys for suggestions you made...
    How can I receive these things from the sending PIC as an example:
    Serout Portb.0, N9600,[$FE,1,"This is the serial LCD Project !!"]
    Jun 2005
    Wisconsin
    If you have windows you could use hyper terminal or you could utilize someone elses lcd application.
    Crematory
    For best performance, connect your LCD to your chosen PIC in 8-bit Data mode, and use a PIC with a hardware USART onboard. You can pick up byte at a time from the receive register and immediately output to LCD. The PICs DATASHEET gives explicit instructions on how to drive the USART. I would not use HSERIN, and certainly not any of the software options like SERIN or SERIN2 etc. Since the timing is not critical for anything other than the USART, pick a Baudrate friendly xtal (like 22.1184MHz or 11.0592MHz) that gives zero errors at the popular baudrates. You should easily handle at least 56kb using this method (not that your LCD would be able to sensibly display that fast - it'll handle it, you just won't see it!).
    Melanie
    PS. I've mentioned before I don't do off-list requests.
  1. LCD serial backpacks
    By Archangel in forum Serial
    Last Post: - 30th December 2010, 05:51
  2. Parallax Serial LCD and issues
    By nbrucew in forum mel PIC BASIC
    Last Post: - 18th September 2009, 05:42
  3. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  4. PIC16F684 + 8*2 LCD module
    Last Post: - 6th March 2008, 00:38
  5. Serial LCD
    Last Post: - 15th November 2007, 09:31
