Lcd And Port A
Results 1 to 2 of 2
Thread: Lcd And Port A
    vicce's Avatar
    vicce Guest
    Default Lcd And Port A
    hello,friends
    I have to connect an LCD display to a PCB board with a 16F877 on
    board.
    LCD data bit are :
    PORTA.2 = D0
    PORTA.3 = D1
    PORTA.4 = D2
    PORTA.5 = D3
    PORTA.1 =E
    PORTA.2 = RS
    I NEED HELP FOR CHANGE THE Pbppic14.lib FOR CAN USED THIS CONFIGURACION
    PS.SORY FOR MY BAD ENGLISH,I AM BRAZILIAN
    Best regards
    VICCE
    Change your hardware design. With PBP the datalines D0-D4 must be connected EITHER from Port bits 0-3, or 4-7, NO OTHER sequence. You cannot start half-way through a Port like you are trying to accomplish (Port bits 2-5). If you absolutely MUST do this, then you have to write your own LCD routines.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD R/S works on Port A but not Port B
    By TDonBass in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 13:41
  4. Running an LCD on different port
    Last Post: - 18th December 2006, 07:41
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
