An other newby, an other blinky probem
Results 1 to 3 of 3
    Maniac's Avatar
    Maniac Guest
    Smile An other newby, an other blinky problem
    Hello
    I've been reading the posts for quite a while. I hoped that I can figure some stuff out by myself... that didn't happen.
    I am trying to program an 18f452, with no luck do far. I have PBP, and a picstart+ programmer. Also, I used a bootloader from Martin Dubuc's site. (http://mdubuc.freeshell.org/) I insert the bootloader's hex file using the picstart+ in MPlab, then using the Colt bootloader to program the chip in the circuit. I can load the sample blink.hex file (Martins) no problem, and it works.
    When I try to load the hex file generated by pbp, it doesn't.
    I checked my .int files, and changed XT to HS, since I am using a 20MHz crystal. I chaned this at the programmer settings as well. I used the code for the blinking led from a book (PIC robotics), from the PBP manual, and from this site. I added the line: define loader_used 1, so the bootloader code is (or should be) protected.
    Anyone would have any ideas what else should I try? I don't have much experience with programming or PICs.
    thanks, and sorry for an other blinky problem
    Attila
    mmm, what if you skip the bootloader process and dump the PBP .Hex file directly to your PIC without the DEFINE BOOTLOADER_USED 1 ?
    Did you also write at the top DEFINE OSC 20 ???
    What about your code???
    Maniac's Avatar
    Maniac Guest
    I did what you suggested and it worked! Thanks!
    I still would like to figure it out why it didn't work with the bootloader. I would like to program the PIC in circuit without taking it out.
    Here is the code I used:
    define OSC 20 '20MHz crystal
    loop:
    high PORTB.1 'turn on LED on RB1
    low PORTB.0 'turn off LED on RB0
    Pause 1000 'wait 1 sec
    low PORTB.1 'turn off LED on RB1
    high PORTB.0 'turn on LED on RB0
    pause 1000 'wait 1 sec
    goto loop
    thanks again
    Attila
  1. DT-INTs Blinky Light question
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 5th February 2010, 04:29
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. Blinky not working with TOGGLE
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 09:45
  4. My first Blinky!
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 25th September 2007, 18:29
  5. Newby with ADC problems.
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 21:09
