max517 don't work
Results 1 to 3 of 3
    Default max517 don't work
    i have a dac max517 in my application which won't run :
    schematic:
                |--V--|
    v-meter ----|     |---- Vdd (Ref0)
    gnd     ----|     |---- Vdd
    scl     ----|     |---- gnd (AD0)
    sda     ----|     |---- gnd (AD1)
    code:
    slad con %01011000 ' slave address 00
    comb con %00000000 ' command byte
    volt var byte ' output voltage
    init : clear
    high sda
    high scl
    volt = 255
    SHIFTOUT sda, scl, 5, [slad, %0\1, comb,  %0\1, volt,  %0\1]
    as result : the v-meter output stays ever 0V. can't see what i make wrong. thanks for any help
    try I2CWRITE instead.. it's still an I2C device
    SDA            var PORTB.0
    SCL            var PORTB.1
    Loop           var Byte
    DACAddressByte CON %01011000 ' DAC Address byte
    DACCommandByte con 0         ' DAC command byte
    start:
        '     this loop will generate simple ramp-up and down
        '     on the DAC output
        For Loop = 0 To 255
            i2cwrite sda,scl,DACAddressByte,DACCommandByte,[Loop]
            pause 10
            Next
        For Loop = 255 To 0 Step -1
            pause 10
            Next
        GoTo start
    Default thanks a lot
    so it works fine, i just include some pull-ups
    was me really a help, thanks again
  1. PortA Doesn't Work
    Last Post: - 8th September 2015, 19:41
  2. pls help me verify my code not work, why???
    Last Post: - 18th January 2010, 10:19
  3. How to set ICD-2 clone to work with PBP?
    By G-R-C in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 03:50
  4. with 40 MHZ osc serin2 not work
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 13th August 2006, 23:56
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
