pls recommend me a module.
Results 1 to 8 of 8
    May 2005
    Default pls recommend me a module.
    any recommendation on cheap bluetooth module to try out?
    Italy
    May 2005
    thnx luciano.. anything one have anything below USD 80?
    Mar 2005
    Iowa, USA
    Lightbulb
    BlueTooth v1.2 DIP Module found HERE. Go to "Wireless communication" and scroll down to the Bluetooth stuff.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Apr 2003
    Cambridge - UK
    www.quickblue.co.uk
    Bluetooth for well under 80usd!!
    National Semiconductor has free samples of BLuetooth serial modules. I have 12 on order, and will let you know how they go.
    Default Zigbee instead of Bluetooth
    I will try soon the xBeePro from MaxStream that reach almost 1.5Km range!
    They are @ 2.4GHz with RS232 in/out up to 240Kbps and controlled through AT commands.
    When I get the results I 'll post it here.
    Oh, and the cost is under 30 Euros!
    Default Re: pls recommend me a module.
    Although back from the dead, Digi modules are easy to work with standard footprint and AT commands or API support. Cost is low and availability not so good I suppose.
    Then there are http://www.synapse-wireless.com same footprint for most of the modules as Digi's and XBee emulator (!) as I can verify with limited compatibility and similar cost, but availability in Europe is a minus.They can be programed in Python (for those who know or want to learn).
    I have also tested some of www.dorji.com modem and ISM modules and can recommend them. Especially the DRF7020D27 module that is powerful tranceiver.
    Google will show many others too.
  1. Version Control
    Last Post: - 16th October 2011, 17:12
  2. Replies: 1
    Last Post: - 27th July 2008, 06:14
  3. Vinculum VNC1L Vdrive2 module problems
    By the_virus in forum Serial
    Last Post: - 21st July 2008, 07:01
  4. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 08:51
  5. Rf module
    By tangray in forum Adverts
    Last Post: - 7th August 2006, 07:14
