UnderWater Antenna 125KHz Driver using a 16F628 @20MHz Example Code
Results 1 to 5 of 5
    Jul 2013
    Default UnderWater Antenna 125KHz Driver using a 16F628 @20MHz Example Code
    Hello,
    I am looking for a PBP 3.1 example of how to implement hardware PWM @125KHz using a 16F628.
    Attached below is a link to the Microchip App note showing the schematic that I intended to build.
    I have an old development board from Bruc Reynolds which is all set up with a 20MHz Xtal.
    From the data sheet...(Linked Below)
    For a device operating at20 MHz, one can obtain a 125 kHz signal by setting theTimer2 prescaler to 1.
    A period of 8 μs is then obtainedby setting the PR2 register to 39.
    To get a 50% dutycycle output, set CCPR1L to 14 and CCP1CON<5:4>to <0:0>.
    These settings will ensure a constant carrier.
    To modulate the data, one can turn the drive signal onand off by setting and clearing the CCP1RIL bit.
    FYI, this is for an underwater antenna that I am experimenting with.
    Jay Zebryk, W1JRZ
    https://ww1.microchip.com/downloads/...tes/00232B.pdf
    Jul 2013
    Default Re: UnderWater Antenna 125KHz Driver using a 16F628 @20MHz Example Code
    This might make things easier:-)
    Name:  Microchip Base Station Schematic.png
    Hi Jay.
    I am not sure what RB3, RB4 and RB7 are used for. I guess the RB3 is the PWM signal output, but the rest?
    As I understand it, you just want a 50% square signal at 125KHz?
    Jul 2013
    Ioannis,
    I have the beast generating 125KHz from the hardware module quite nicely.
    To modulate a data stream, I am simply changing
    TRISB.3 from an Output to an Input.
    Peace,
    Jay Zebryk
    So, you are generating the 125KHz 50% duty cycle signal?
  1. HX711 driver code
    By povulon in forum General
    Last Post: - 28th April 2021, 09:39
  2. Underwater speed?
    By Ramius in forum General
    Last Post: - 21st December 2014, 13:53
  3. Replies: 3
    Last Post: - 12th March 2008, 05:33
  4. i need driver code for infineon's sle4428
    By steve_st23 in forum General
    Last Post: - 5th March 2006, 17:20
  5. Driver code for 14 segment LED display
    By Durward Searcy in forum mel PIC BASIC Pro
    Last Post: - 12th December 2004, 20:08
