How to set port to high impedance? TRIS seems not to be working.
Results 1 to 8 of 8
    OK
    Default Re: How to set port to high impedance? TRIS seems not to be working.
    In your example code you clear all TRIS bits making them all outputs. Try:
    TRISA = 111111
    TRISB = 111111
    TRISC = 111111
    frak:
    TRISA.6 = 0
    TRISC.3 = 0
    HIGH PORTA.6
    LOW PORTC.3
    PAUSE 2
    LOW PORTA.6
    HIGH PORTC.3
    PAUSE 2
    TRISA.6 = 1
    TRISC.3 = 1
    TRISC.1 = 0
    TRISC.2 = 0
    HIGH PORTC.1
    LOW PORTC.2
    PAUSE 2
    LOW PORTC.1
    HIGH PORTC.2
    PAUSE 2
    TRISC = 0
    GOTO frak
    As I understand, that RMW issue might happen due to current flowing in reverse direction thru the one of the led segments.
    For the latch part, I'll try one, too bad there is no search option to tell, which part has latch and which does not.
    OK
    Newer PICs have LATx registers that eliminate the RMW issues.
    charlieplexed correctly latx regs are not required at all
  1. 16F887 - PORT pins interfere with each other when set high/low
    Last Post: - 22nd June 2020, 17:06
  2. Replies: 28
    Last Post: - 9th March 2015, 16:35
  3. How to set a pin high an keep it there?
    By ShortBus in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 17:01
  4. 16F877A Correct set up for port a
    By enigma in forum General
    Last Post: - 30th March 2008, 13:00
  5. Pulling port high
    By the_antique in forum mel PIC BASIC Pro
    Last Post: - 14th November 2005, 19:18
