12LF1552 -- support?
Results 1 to 3 of 3
    Default 12LF1552 -- support?
    I ordered some 12LF1552 I need for extra ram. Microcode supports it but does PBP gold edition? Can't find that info at melabs.
    Also -- is there anything peculiar or special I need to know when I configure it in my picbasic code?
    THANKS !
    OK
    Default Re: 12LF1552 -- support?
    It appears to have a unique analog feature CVD. I've not used it, but it involves an output pin. You might want to look that over, as it is not a common feature. My PBP3.1 Gold supports the PIC12LF1552. It's old enough I doubt it was added in any recent updates.
    There's a list of supported devices available here: https://pbp3.com/devicelist.html and it lists the 12LF1252. Microcode Studio populates the list of microcontrollers from the available supportfiles of the compiler. If you do see the device in the dropdownlist you should be able to compile for it.
  1. Thanks for the support group
    By F1CHF in forum General
    Last Post: - 30th April 2012, 08:37
  2. SPI support
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 7th March 2012, 03:58
  3. Support Australia
    By T.Jackson in forum General
    Last Post: - 12th May 2007, 09:49
  4. support
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 14:06
  5. CAN support
    By schu4647 in forum PBP Wish List
    Last Post: - 5th July 2006, 01:41
