No Data out of RCREG
Results 1 to 4 of 4
    first thing i notice, as you don't use any HSERIN/HSEROUT, i doubt the HSER_BAUD will do something for you so what about if you remove it and use
    SPBRG=39?
    next one have a look to the following link. It could be handy.
    http://www.picbasic.co.uk/forum/show...1&postcount=11
    AND the following could be interesting too.. i just can't remind where i have posted it here. BTW have fun
        '   Simple program to handle USART interrupt using PIC16F877 @20MHZ
        '   This program will Blink a LED on PORTB.0 to show
        '   that the PIC is running.
        '   This program also allow the user to activate or deactivate
        '   a LED connected on PORTB.1 pin by sending command from a PC
        '   terminal software using 9600,n,8,1 setting
        '   User command:
        '                1. If character "1" is received => enable the LED
        '                2. if character "2" is received => disable the LED
        DEFINE LOADER_USED 1        ' using bootloader
        DEFINE OSC 20               ' running at 20 MHZ
        '    PORT setting
             TRISC=%10000000        ' RC.7 => USART RX pin set to input
                                    ' all other pin set to output
             TRISB=0                ' RB<7:0> set to output
        '    USART setting
             ' Since we will not use HSERIN/HSEROUT, we must
             ' write directly to internal PIC register
             TXSTA=$24              ' enable transmit and SPBRGH=1
             RCSTA=$90              ' Enable USART and continuous receive
             SPBRG=129              ' BAUD RATE = 9600 BAUDS
        '    Interrupt definition
             PIE1.5   =1            ' enable USART receive interrupt
             INTCON.6 =1            ' enable peripheral interrupt
        '    Alias definition
             RCIF      var PIR1.5   ' receiver interrupt
             StatusLED var PORTB.0  ' the LED who show a 'running process'
             UserLED   var PORTB.1  ' the LED that user want to control
        '    Variable definition
             Delay     var word     '
             DataIn    var byte     ' use to store RCREG content
             Discard   var byte     ' use to erase RCREG register
        '    Hardware/software initialisation
             PORTB=0                ' clear PORTB
             on interrupt goto USARTInterrupt
    Start:
        '    Main program loop that make the user happy to
        '    see a LED flashing to mean that something is
        '    running
        toggle statusled
        for delay = 1 to 5000       ' use a loop delay to ensure
          pauseus 5                 ' getting interrupt as fast as
          next                      ' possible
        goto start
    disable interrupt
    USARTInterrupt:
        '    Here's the interrupt routine who will make the user
        '    much happy by giving him the feeling to have the
        '    control on the machine when the status of the user
        '    LED will change
        RCSTA=0                     ' Disable serial port AND
                                    ' clear possible error (FERR,OERR)
        datain=RCREG                ' Get data
        while RCif                  ' wait untill the RCREG is empty
              discard=RCREG         ' by reading it and store result in a
        wend                        ' don't care variable
        select case datain          ' What to do with that data???
               case "1"             ' User selection = 1
                    userled=1       '      => Enable the LED
               case "2"             ' User selection =2
                    userled=0       '      => disable the LED
               end select
        RCSTA=$90                   ' Re-enable the serial PORT AND
        resume                      ' get out of here
    enable interrupt
    So in your code yes you can receive something... is this a valid data? i don't think so. You can even have an interrupt by sending an audio signal or else to your USART. So BaudRate is the main problem... i guess or you don't use any RS-232 inverter like MAX232
    grayfuse's Avatar
    grayfuse Guest
    Default Thanks!
    That was the problem, thanks a lot! Never took into account the Define was a PBP define that wasn't doing specifically what I needed.
    Thanks again!
    PBP define will work only if you use HSERIN/HSEROUT. While you don't use them but interrupt, they'll not be considered.
    Thanks to Bruce for this precious discover many times ago !
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
