1 microsecond rising edge pulse detection
Results 1 to 3 of 3
    Apr 2016
    Plainfield, Illinois
    Default 1 microsecond rising edge pulse detection
    Can anyone think of how to detect a TTL 1 microsecond pulse using just a PIC? I'm not measuring the width - just the rising edge. I dont think I can do it using a 16f616. I'm afraid I'll have to use a 555 timer to do this but dont want to yet.
    My dad never liked you...
    OK
    Default Re: 1 microsecond rising edge pulse detection
    I've never worked with that part number, but it should have an INT or INT0 function. Somewhere (INTCON is where I find it on the PICs I play with) there is a bit to determine if you get an Interrupt on Rising or Falling Edge. On that old of a chip, the pin will probably be specific and non-transferable (ala PPS).
    Yes, the datasheet specifies INT pin input high or low time: Minium 25ns so should be no problem with 1us. Question then becomes how much latency you can accept, how fast do you need to "react" on that pulse? Either you'll setup an actual interrupt OR you simply poll the interrupt flag.
  1. Shiftout data needs to be sent on rising edge of clock
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 10th December 2012, 22:43
  2. Need some suggestion ignition coil pulse detection
    By phoenix_1 in forum Schematics
    Last Post: - 28th April 2009, 23:34
  3. newbie Q - edge detection?
    By RMCRAVEN in forum mel PIC BASIC Pro
    Last Post: - 9th October 2006, 08:20
  4. Best way to find a rising edge?
    By jcsquire in forum mel PIC BASIC Pro
    Last Post: - 31st May 2006, 15:11
  5. Replies: 2
    Last Post: - 5th June 2005, 19:55
