Simple TTL input pin coding.
Results 1 to 4 of 4
    Apr 2016
    Plainfield, Illinois
    Default Simple TTL input pin coding.
    New to PIC basic - programming a 16F15324 - a substitute of the 16F616. I'm setting up pin 2 of the IC to be a simple 0 or 1 detector w 5V.
    It will not detect a 1 or a zero unless I make the pin a analog pin as shown below. I do not understand this as its a I/O pin = not analog.
    What am I not grasping here?
    port A is an input - C is an output
    please help... thanks
    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_OFF
    __config _CONFIG2, _MCLRE_ON & _PWRTE_ON & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF & _STVREN_ON
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_6 & _WDTCCS_SC
    __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTSAF_OFF & _LVP_OFF
    __config _CONFIG5, _CP_ON
    ANSELA = PORTA.5
    TRISC = %00000000
    LED VAR PORTC.3
    BNC1 VAR PORTA.5
    IF BNC1 = 1 THEN
    HIGH LED
    My dad never liked you...
    Default Re: Simple TTL input pin coding.
    This should make it work
    TRISA.5 = 1 'make porta.5 input
    ANSELA.5 = 0' make porta.5 digital
    LED VAR LATC.3 ' Use lat for output and port for input
    It's really important to search and study the datasheet for answers. Read the datasheet starting at page 178 "Analog Control"
    OK
    pescador, "ANSELA = PORTA.5" != "TRISA.5 = 1 'make porta.5 input". You are setting your ANSELA SFR to either %00000000 or %00000001, depending on the state of PORTA.5. Neither will do what you want.
    Apr 2016
    Read the data sheet - love that answer.. First of all I wouldn't even think to look at the analog portion of the documentation since I'm not using analog inputs. The fact is the pins are defined as analog by default would have been good to know obviously. In any case - I got it to work using your code. Thank-you.
  1. Using MCLR pin at Input
    By JakeMend in forum mel PIC BASIC
    Last Post: - 6th July 2017, 22:39
  2. Use any pin as tmr input?
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 11th October 2016, 20:50
  3. Mclr As Input Pin?
    By omid_juve in forum mel PIC BASIC Pro
    Last Post: - 24th December 2007, 06:33
  4. Input pin help
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2007, 09:35
  5. TTL input - 3rd states possible?
    Last Post: - 31st March 2007, 16:04
