Matrix keyboard with State Machine
Results 1 to 8 of 8
    Default Re: Matrix keyboard with State Machine
    Mike, this is Stamp Basic dialect.
    Richard, thanks. This makes more sense now. Yes maybe there is better code for matrix keyboard. I was interested in this because of the debouncing and scanning all at the same time.
    See the code examples from Les Johnson in second post. I had this book many years ago, now out of print. You can find pdf's copies on google
    http://www.picbasic.co.uk/forum/showthread.php?t=21115
    Bombay, India
    If you're able to understand arduino C, look at the arduino matrix keyboard example. Nice FSM implementation https://domoticx.com/arduino-library-keypad/
    Thanks to all!
    I did this a long time ago with a 4X4 membrane switch to play messages on an ISD chip.
    Low PORTC.7
    Pause 1
    IF PORTB.4 = 0 Then MESSAGE1
    IF PORTB.2 = 0 Then MESSAGE9
    High PORTC.7
    Low PORTC.6
    Pause 1
    IF PORTB.4 = 0 Then MESSAGE2
    IF PORTB.2 = 0 Then MESSAGE10
    High PORTC.6
    Low PORTC.2
    Pause 1
    IF PORTB.4 = 0 Then MESSAGE3
    IF PORTB.2 = 0 Then MESSAGE11
    High PORTC.2
    Low PORTC.1
    Pause 1
    IF PORTB.4 = 0 Then MESSAGE4
    IF PORTB.2 = 0 Then MESSAGE12
    High PORTC.1
    Low PORTC.0
    Pause 1
    IF PORTB.4 = 0 Then MESSAGE5
    IF PORTB.2 = 0 Then MESSAGE13
    High PORTC.0
    Low PORTA.0
    Pause 1
    IF PORTB.4 = 0 Then MESSAGE6
    IF PORTB.2 = 0 Then MESSAGE14
    High PORTA.0
    Low PORTA.1
    Pause 1
    IF PORTB.4 = 0 Then MESSAGE7
    IF PORTB.2 = 0 Then MESSAGE15
    High PORTA.1
    Low PORTC.4
    Pause 1
    IF PORTB.4 = 0 Then MESSAGE8
    IF PORTB.2 = 0 Then MESSAGE16
    High PORTC.4
  1. another state machine example
    By richard in forum Code Examples
    Last Post: - 19th October 2021, 13:27
  2. Matrix keyboard for up to 32 keys
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 21st June 2009, 02:43
  3. Keyboard Matrix with a Twist
    By k3v1nP in forum mel PIC BASIC Pro
    Last Post: - 29th October 2008, 11:51
  4. State machine programming
    By tjstevens in forum mel PIC BASIC Pro
    Last Post: - 17th April 2007, 23:45
  5. Matrix keyboard problem
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 9th May 2005, 19:50
