12F683 EXTERNAL CRYSTAL CONFIG for DTMFOUT statement
Results 1 to 4 of 4
    Jan 2022
    Default 12F683 EXTERNAL CRYSTAL CONFIG for DTMFOUT statement
    Hello,
    I currently using a 12F683 at 8mhz internal osc, with this code below and it's working fine no problem at all.
    ; __config _INTRC_OSC_NOCLKOUT & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _BOD_OFF & _CP_ON & _CPD_OFF
    OSCCON = $70 ; 8mhz
    This is the config set from meConfig setup program:
    __config _INTOSC & _WDT_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
    Now I need to use the same 12F683 chip with an 16mhz and/or 20mhz external crystal,
    What do I need to change to make it work at 16 or 20mhz external crystal, please provide both config 16 and 20mhz crystal.
    Thank's to reply.
    Default Re: 12F683 EXTERNAL CRYSTAL CONFIG for DTMFOUT statement
    At the top Define 16mhz or 20mhz
    OSCCON = 0
    In the config replace
    _INTOSC or _INTRC_OSC_NOCLKOUT with _HS_OSC
    Jan 2022
    Thank's Mark_s for the quick reply,
    I did changed theses lines, but there's one thing is odd, I have to turn MCLRE_ON to "on" if it's "OFF" nothing is working properly
    look at my listing, I did this to test if the Pic is running at 16mhz,
    Cheer,
    __config _HS_OSC & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
    OSCCON = 0
    DEFINE OSC 4 ;RUN 4X 16MHZ CRYSTAL
    ;DEFINE OSC 16 ;RUN 1X 16MHZ CRYSTAL PAUSE 1000 = 1 SEC
    ANSEL = 0 ; Set all digital PULLUP Resistor page:10
    CMCON0 = 7 ; Analog comparators off
    LED Con 0
    DO ; main loop
    TOGGLE LED
    PAUSE 1000
    LOOP
    Jan 2022
    Quote Originally Posted by jackberg1 View Post
    Cheer,
    OSCCON = 0
    LED Con 0
    DO ; main loop
    TOGGLE LED
    PAUSE 1000
    LOOP
    ----------------------------------------------- NEW CONFIG SEEM TO WORK ----------------------------------------------
    IF DEFINE OSC 4 LED BLINK 2 times on-off / 1 sec FOR 16MHZ CRYSTAL
    IF DEFINE OSC 8 LED BLINK 1 times on-off / 1 sec FOR 16MHZ CRYSTAL
    IF DEFINE OSC 16 LED BLINK ON 1 SEC, BLINK OFF 1 SEC, FOR 16MHZ CRYSTAL
    Let me know if this new config is correct.
    Thank's again for comments.
    ; config setup from meConfig program
    __config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_ON & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
    ;OSCCON = 0
    ;DEFINE OSC 4 ;RUN 4X 16MHZ CRYSTAL
    ;DEFINE OSC 8 ;RUN 2X 16MHZ CRYSTAL
    LED Con 0
    DO ; main loop
    TOGGLE LED
    PAUSE 1000
    LOOP
  1. Replies: 8
    Last Post: - 20th March 2017, 09:34
  2. how to use external crystal?
    By tbarania in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2015, 15:43
  3. 1 x external crystal oscillator for multiple PICs
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 27th November 2013, 14:05
  4. 12F683 - how to set it to use external 4 MHz clock?
    By jimbostlawrence in forum mel PIC BASIC Pro
    Last Post: - 29th September 2009, 09:16
  5. 16f877A and tmr1 external crystal question
    By comwarrior in forum General
    Last Post: - 13th July 2009, 00:40
