Advice on melabs programmer
Results 1 to 5 of 5
    Default Re: Advice on melabs programmer
    The PIC's that are programming properly are 8 pin 12F629, 12F675 and 12F683. The 28 pin PIC's programming properly are 16F73 and 16F872. It's only the 16F819 that doesn't work.
    Is your pic16f819 the 18 or 20 pin version? Check the data sheet. The programming pins are not in the same location. Your mclr, PGC and PGD need to line up in the ziff socket. If you are doing in circuit programming check your wiring again.
  1. Melabs U2 programmer needed
    By jmgelba in forum Off Topic
    Last Post: - 23rd February 2013, 01:49
  2. FS: melabs U2 Programmer $50
    By gtrplaya101 in forum Adverts
    Last Post: - 18th July 2012, 16:24
  3. Melabs U2 Programmer
    By JTCullins in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2011, 15:01
  4. Melabs U2 Programmer question
    By polymer52 in forum Off Topic
    Last Post: - 23rd July 2010, 14:10
  5. MELABS Serial Programmer help
    By nigelstephens in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2007, 21:01
