Serial LCD display for PIC projects ?
Results 1 to 11 of 11
    Feb 2022
    Default Serial LCD display for PIC projects ?
    Greetings to the Community.
    Would you have a serial display to propose to me, compatible with our PIC projects (Kit, schematic or website).
    In fact, also user of MCU Basic picaxe I have the serial displays AXE 133 and 134 (2x16 and 4 x 20 OLED display), driven by a Picaxe.
    But these do not display correctly the signals coming from a Port leaving a SEROUT signal ...
    Thanks in advance.
    Default Re: Serial LCD display for PIC projects ?
    i see no good reason why those displays would not work with pbp
    what code have you tried and how have you wired it up
    Feb 2022
    Hi Richard,No, no reason, I thought!
    But the reality seems unfortunately different.
    To use the serial display driven by a (Basic)Picaxe; the picaxe command is Serout, pinx, N2400_4 or N2400_16 depending on the picaxe used.
    But, with PBC, the command Serout, pinx, N2400 does not give the same chronogram !?
    See attached image.
    I try to use this display (AXE 134), or find another model compatible with my PIC.
    ThanksName:  _SEROUT.jpg
    Bit timing seems to be in the ballpark for 2400 but apparently the PICAxe has quite a bit of delay between each byte (usually not what you want to see). If the display(s) do work with the PICAxe and the timings you show are correct then you can force PBP to insert extra delay between each byte it sends by inserting the following line.
    DEFINE CHAR_PACING 500
    This will insert 500us delay between bytes (when using SEROUT) which should then match the PICAxe timing.
    If you switch to SEROUT2 then the above DEFINE doesn't work so check the manual if that's something you're planning to do.
    I'm not into PICAxe but if I'd guess the _4 and _16 tacked onto the end of the SEROUT command simply specifies which routine to call based on if you're running at 4MHz or at 16MHz. In PBP you use DEFINE OSC 16 and the compiler automatically handles the timing for SEROUT (and other stuff).
    Feb 2022
    Hi Henrick;
    This forum is great!
    Thanks a lot for your intervention!
    With:
    DEFINE OSC 16
    Symbol BAUD = N2400
    The three pulse bursts are well separated by 0.92msec and the display responds well.
    What is the relationship between parameter 500 and the 0.92msec timing?
    Why not 500µsec?
    Testing:
    If I test with DEFINE CHAR_PACING 1000, the difference is 1.4 msec and the display is a bit slower.
    On the other hand, with DEFINE CHAR_PACING 250, the gap between the bursts is 0,64msec and the display does not work anymore.
    Feb 2022
    Here is the simple code:
    ' Programme: Test SEROUT.PBP
    ' RGL 02-2022
    ' Testing AXE134 (Picaxe 4x20# OLED Display) ---> PIC 16F630
    ' PicBasicPro Compiler V:2.40
    Include "modedefs.bas"
    ' Pic Specifications
    'PIC16F630 with 16Mhz resonator
    @ Device Pic16F630,HS_OSC, WDT_OFF, PWRT_ON, PROTECT_OFF, MCLR_OFF
    CMCON = 7 'Deactive Comparator RA0+, RA1-, RA2 out
    DEFINE OSC 16
    ' ******* VARIABLES / CONSTANTS **************************
    Symbol BAUD = N2400
    Symbol OLED = PORTA.0 'pin13
    '*** Definition i/o
    'All OUTPUT
    TRISA = 0
    TRISC = 0
    Pause 1000
    Serout OLED, BAUD,[254,1] : pause 30 ' Clear Display
    Serout OLED, BAUD,[254,128] : PAuse 30 ' Line1, Col1
    LOOP:
    Serout OLED, BAUD, ["UUU"]
    Pause 1000
    Goto Loop
    Why not 500µsec?
    Because at 2400 baud ~420us of that 0.92ms is the normal stopbit. Add to that the additional character pacing of 500us.
    At 2400 baud you'd also get the same result by specifying two stop-bits.
    Feb 2022
    Great Henrick!
    Thank you for your clear and quick answers.
    Have a nice evening.
    Feb 2022
    @Henrick
    I have drawn the timeline in the case of a transmission of two spaced bytes with the command DEFINE CHAR_PACING 1000.
    I can see, however, that in addition to the normal Start bit of 410µs, another delay of 410 µs is added to the Pacing 1000!?
    Name:  Serial Burst.jpg
    No, you're forgetting the stop-bit! You have 1 startbit, 8 databits and 1 stopbit.
    In your diagram, from left to right: First you have the start-bit (1), then you have 8 data-bits (11000010), then you have the stop-bit (0) and THEN you have the 1000us CHAR_PACING before the next start-bit.
    Feb 2022
    OK Henrick.
    I have corrected my drawing accordingly.
    It should be OK like that.
  1. Need RFID PIC TAG with a LCD display
    By khalidjamil007 in forum mel PIC BASIC Pro
    Last Post: - 18th January 2010, 14:08
  2. Replies: 6
    Last Post: - 4th April 2007, 07:33
  3. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 07:35
  4. serial LCD display?
    By ra68gi in forum mel PIC BASIC Pro
    Last Post: - 12th March 2006, 20:05
  5. SMART Serial 4 Digit LCD Display (SMARD4)
    By paul borgmeier in forum Adverts
    Last Post: - 5th January 2005, 05:50
