An other newby, an other blinky probem
Results 1 to 3 of 3
    mmm, what if you skip the bootloader process and dump the PBP .Hex file directly to your PIC without the DEFINE BOOTLOADER_USED 1 ?
    Did you also write at the top DEFINE OSC 20 ???
    What about your code???
    Maniac's Avatar
    Maniac Guest
    I did what you suggested and it worked! Thanks!
    I still would like to figure it out why it didn't work with the bootloader. I would like to program the PIC in circuit without taking it out.
    Here is the code I used:
    define OSC 20 '20MHz crystal
    loop:
    high PORTB.1 'turn on LED on RB1
    low PORTB.0 'turn off LED on RB0
    Pause 1000 'wait 1 sec
    low PORTB.1 'turn off LED on RB1
    high PORTB.0 'turn on LED on RB0
    pause 1000 'wait 1 sec
    goto loop
    thanks again
    Attila
  1. DT-INTs Blinky Light question
    By circuitpro in forum mel PIC BASIC Pro
    Last Post: - 5th February 2010, 03:29
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. Blinky not working with TOGGLE
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 08:45
  4. My first Blinky!
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 25th September 2007, 17:29
  5. Newby with ADC problems.
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 20:09
